Well to start if you want a job done right don't get any of my mates to do it lol
These twats did a motor swap to do this they cut the trani lines (TWATS) now I have the great job of finishing it dose the top hole in the trani for the cooler line go to the top hose of the cooler im assuming so but need to double check as it aint my car
Thanx in advance
a crude method , i think , would be to have both pipes/lines not connected to anything & start/crank the engine momentarily to identify which line fluid comes out of .
drop it in drive with the brake on if necessary .
( 1 line disconnected at the trans & the other 1 disconnected at or close to the cooler )
then connect the line which the fluid comes out of to the top of the cooler .
i'm assuming the flow is the same as a radiator - hot to the top & draws cool/er from the bottom .
The line that sits slightly on the top goes to the bottom.
