Results 1 to 5 of 5
Thread: power window wiring help
    vr berlina
    Mar 2009
    Default power window wiring help
    i currently have a vr belina with factory standard power windows but i have been having issues with them as of late they lose power a minute or 2 after unlocking my car is there any way i can rewire them so they dont run off the bcm and how do i do it a bit of detail may be required im a bit newish to the wiring in it
    VS Ute & VZ SV6 Sedan
    Nov 2007
    to post details , i reckon , would be too long & involved etc .
    try a gregories manual for the wiring diagrams & go from there .
    or another bcm & or keyhead ? brandnew straight from the wreckers . lol .
    i've read that here somewhere , brandnew , from the wrecker . nothing wrong with that
    just sounds funny .
    trivia : i've not long fitted a passenger side power window & a cat 793 pwr window switch to control it , next , the drivers side & a pwr mirror switch to control them all - bench seat series 1
    not much independant down control but i'll have UP control !
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Sounds like the battery/alternator. Do they go faster with the car running if so, then it's prob ur battery. Try whacking some grease in the rails that the windows sit in and see how you go from there. I know mine act a little slower with the motor switched off but that's normal... If they are really slow then sounds like your battery.
    vr berlina
    Mar 2009
    its not a issues with the up and down its a issue with no power to make em work
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Quote Originally Posted by buster1192 View Post
    this is a factory thing, once the car is unlocked the pwr windows along with the interior light are turned on for 30sec. the real only way to do it is to get a electronic kit that either a. u can adjust the delay, or b. only set it for a longer time frame. Hook it to where it gets power feed from the bcm and buy pass it. doing this you may also disable your auto-down feature
  1. power window wiring
    By buster1192 in forum Electrical Wiring / Questions
    Last Post: 12-07-2009, 08:16 AM
  2. VN power window wiring diagram
    By combatantsomeone in forum Electrical Wiring / Questions
    Last Post: 09-02-2009, 07:01 PM
  3. Power window wiring
    By Pav in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-12-2008, 04:39 PM
  4. power window wiring diagram
    By sumsle in forum Electrical Wiring / Questions
    Last Post: 21-10-2008, 05:31 PM
  5. power window wiring
    By crainy in forum Electrical Wiring / Questions
    Last Post: 19-07-2005, 08:34 PM
