Results 1 to 7 of 7
Thread: Another VS Heater Question
    VS wagon
    Dec 2007
    Default Another VS Heater Question
    Long story short
    Heater tap broke last year so I bypassed the heater.
    It got Bl**dy cold now so I got a new heater tap and installed it
    BUT still no heater.
    Now have no vacuum at the tap but my understanding is if there is no vacuum the water is channeled to the heater?
    So no vacuum heater works
    SO have I connected the tap properly
    Can someone please maybe take a pic of there heater tap to see if all is OK
    Then Ill look into the Vac problem
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Just taken a pix - hope it gives you the required info. Good Luck
    Attached Thumbnails Attached Thumbnails Another VS Heater Question-heater-tap.jpg
    VS wagon
    Dec 2007
    Quote Originally Posted by hako View Post
    Thanks Very Much
    Wondering if you could take another showing the vac line side or from top
    Will give more indication of orientation
    Thanks
    greenacc's Avatar
    greenacc is offline Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Nev25 , have you tried flushing water through the heater with the hose ? your heater could be blocked if you let it dry out while it was disconnected.
    Just from memory i think the top hose from engine goes to top of heater tap ( front side) , bottom to bottom, and so on.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Nev25 View Post
    Thanks Very Much
    Thanks
    Here is the pix from on top. As greenacc says, the top hose from engine goes to top connection on heater tap...same on other side - top to top, botom to bottom.
    When I installed my new tap I found it easier to remove the bracket from the inner mudguard and attach the tap to it then attach hoses and finally bolt back to inner guard.
    Attached Thumbnails Attached Thumbnails Another VS Heater Question-heater2.jpg
    VS wagon
    Dec 2007
    Thanks Ill look today
    Pretty sure thats the way mine is but heater still dont work
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I've seen where the heater has sprung a leak and to stop coolant going thru the heater they have put a short length of 5/8" steel rod in both heater hoses to stop the flow. Pretty dodgy but it usually fools the mechanic when he's issuing a roadworthy certificate. Hope this ain't your problem.
  1. heater question
    By fishman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-04-2007, 09:13 PM
  2. question on heater air con motor!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-12-2006, 09:36 PM
  3. Heater question.
    By SoulGrind in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-04-2006, 06:05 AM
  4. stereo and heater control question
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-12-2005, 05:58 AM
  5. heater/air con question
    By jaikai in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-08-2005, 12:13 PM
