Results 1 to 4 of 4
Thread: VS 5.0L air vent issue
    VS 5.0 Ute
    Feb 2009
    Default VS 5.0L air vent issue
    Having a drama with my ute air vents. No matter what the selector is on the air only comes out the feet vents. There is a constant hissing from behind the vent selector but all the vacuum lines seem to be plugged in and un-broken. Where should I be looking now to fix this?
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    u shouldnt hear any hissing at all, cept when u change the selector and then only for few seconds... could be a hole in vac hose behind the selector or a crack in the selctor bit where the vac hoses go on... maybe look at gettn a secondhandy and rule the selector bit out
    VS 5.0 Ute
    Feb 2009
    whats the easiest way to get the selector out? I managed to undo it all but the little metal pole that joins to the heat selector was still attached and I couldn't work out how to get it off without ripping it out in a fury. If I could undo that I could get the rest out to test/replace
    May 2006
    Perth, Western Aust
    the little metal pole runs thur to where the drivers leg sorta goes if tya pop ya head under there u will see there is white connector lever on the hvac box which the metal pole goes thru.. its like aflap over it just stick ya finger nail under it and flip it up.. pole then falls out
  1. Fan Vent Selector
    By Kersh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-05-2011, 01:04 PM
  2. Air vent
    By Robbo5390 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2008, 09:59 AM
  3. VX Series 2 Executive - Start Issue + Boot Button Issue!
    By stig1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-06-2008, 02:28 PM
  4. VS C/C vent fault
    By crawfy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2008, 02:14 PM
  5. air vent question.
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-11-2007, 05:31 PM
