Results 1 to 4 of 4
Thread: Lsd vs commodore
    Vs Equipe
    Oct 2006
    Default Lsd vs commodore
    hey all im thinking of buying a lsd for my non irs commodore , the diff in question is from a vr commodore that has abs my car dosent have abs will this diff work in my car or is it abit to much to play around with to get it working cheers all
    '97 VS II Statesman 5.0L 5-Speed
    Feb 2006
    Radelaide
    just change the centres, itll be fine. my statesman has ABS, when i put the LSD in it (that came out of a car without ABS) i had to use my old diff hat cause of the wheel speed sensor brackets, IRS though
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    im only thinking out loud so dont take this as gospel. ABS diff in my thoughts would only have some tabs welded on it somwhere so the abs can read the output shaft speed. So the actual diffs themselvse shouldnt be different, and theres no reason i can think of if you fitted it why it would not work, the abs is only a proxy picking up some tabs on a shaft, nothing to do with its operation at all, only external monitoring basically.
    Reaper
    94 VR Statesman
    Aug 2006
    yeah VrWagz is right
  1. Commodore S ....Commodore SS... is there a difference..??
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-12-2009, 03:23 PM
  2. Replies: 6
    Last Post: 17-05-2009, 10:57 PM
  3. Do VN V6 Commodore injectors fit a VR V6 commodore
    By ozzybloke01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-09-2007, 04:43 PM
  4. VN commodore exhaust into VR commodore
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2006, 09:38 PM
