Results 1 to 7 of 7
Thread: VS Climate control
    VS Aclaim II 3.8Ltr
    Jan 2009
    Default VS Climate control
    looking at getting climate control for my VS, does anyone know if the unit goes straight into a VS aclaim?
    VS Berlina 3.8
    Dec 2008
    Climate control is a massive job, the module will go in but it does not simply plug and play. Different heater box, cabin sensors, looms, etc...
    If you're still keen, 88GreenVN did it (anybody correct me if I'm wrong).
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    It can be done but is one massive job! I did it just for the sake of doing it and replaced the heater core at the same time as mine was leaking badly.
    It took me a whole weekend to do so its not for the faint hearted and someone who isn't afraid of dealing with the electrics.
    I used 88GreenVN's how to and also used a few different manuals to get mine going but I also stripped a lot of wiring out of a wreck to do the job.
    The entire job will require the HVAC unit to be changed to some degree and also the removal of the dash and also the AC pipes, so its better if the AC is not working in the first place.
    I have done this in my VR work hack but luckily it has worked out for the best so far
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    VS Aclaim II 3.8Ltr
    Jan 2009
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Well there you go - it can be done on a VR/VS without swapping to a L3 loom.
    A weekend is about right - if you know how to take the dash apart - bit longer if you've not donre it before.
    and 3 Dangerous non ABS VN's
    vr with ecotec
    May 2009
    i just did it to my vr ute and yeah its a big job but i had a complete vs wreck sitting next to me to take it all from. just watch out for the heater pipes cause they will hold the unit in there and you dont want to bend them to much.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by scoota72 View Post
    Did you swap looms aor graft it in - did everything work after the install - like rear demister?
  1. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  2. Climate control
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-12-2008, 06:51 PM
  3. Vn-vs Climate Control
    By struggo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-02-2007, 09:10 AM
  4. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  5. Climate Control
    By TigerVX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2005, 06:12 AM
