Results 1 to 6 of 6
Thread: Injectors - Will VS-VY(Ecotec) fit VR (Buick)
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Question Injectors - Will VS-VY(Ecotec) fit VR (Buick)
    Hi Guys,
    I'm looking at some supercharged motor fuel injectors for my VR Series 2.
    Will Ecotech ones fit the Buick Motor
    Also any advise on psi:cc ratio requirements would be great (i.e. what cc rating injectors are recommended for different psi levels)
    Thanks
    I've made her a Hold-On Commodore
    Foam Tuned 1995 VR Series II - 9psi Boost - Manual - FM Intercooler - 3" S/Steel Plumbing
    Super6 Injectors - Ceramic Wrapped Genie Extractors - 2.5" HiFlow Cat - 2.5" HiFlow Catback Exhaust with a 4" Dump Resonator
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    they will fit but u will need the fuel pressure reg to go along with it it runs at a higher pressure, but the VT+ injectors actually flow 1cc less than the VR-VS injectors.
    ur betting off going magna injectors, higher flow rate, and low cost.
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    why do you need supercharged jectors
    they wont make anything better on stocker
    if your going forced induction magna ones wont cut it
    1995 VR, 1987 VL
    May 2009
    East Gippsland, Vic
    Quote Originally Posted by daron View Post
    Dude, I have supercharged my VR (as you can see in my signature), hence why i'm asking about getting the appropriate injectors to suit the SC motor.
    i've heard a bit about the magna ones, but yes i have also heard that they aren't good enough for SC motor, that's why i'm asking if the SC VS-VY ones suit
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if you plan to up the boost yeah 36lb S/C injectors fit will need a tune to run them and a tune for a 2 bar sensor forget about rising rate regs they arnt needed either just a waste of dollars and are not needed with a tune and big injectors
    daron's Avatar
    VE SSV
    Mar 2006
    adelaide
    sorry i dont read sigs but now i see you are chared at 4psi your injectors will be fine
    if you up ya boost do as delcokid says get the s/c 36's
  1. buick or ecotec
    By MAC-VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2009, 06:00 AM
  2. VT injectors into buick V6?
    By Adamvr93 in forum V6 Development And Modification
    Last Post: 12-02-2009, 06:27 PM
  3. Ecotec or buick?
    By vkwalks39 in forum General
    Last Post: 14-09-2008, 09:53 AM
  4. ecotec vs buick
    By brend0n in forum V6 Development And Modification
    Last Post: 18-06-2008, 08:20 AM
  5. Buick injectors
    By ecotec38 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-01-2008, 04:56 PM
Tags for this Thread
