Hey guys started my car up today and when she kicked ova she spitted and spattered for about 10 seconds idling quiet ruff b4 i gave it a bit of a rev and then she was idling normal again... I turned the car off and kicked it ova again and then she was fine???? could it be my fuel pump on its way out?
could be a 101 things 1 eg dirty injector, bad lead etc. i wouldnt worry about it unless it starts doing it frequently.
check out the other vs rough at startup thread i think phsyco pheniox just fixed his by cleaning his earth points
mine started doing this and after plugs and leads she was fine
I had the same issue,
New plugs, Leads, Fuel filter & putting some Injector cleaner in with a tank of fuel.... Never had the prob since.
Yeah check the phsyco pheniox post if none of what i suggested helps.
Cheers.
I've made her a Hold-On Commodore
Foam Tuned 1995 VR Series II - 9psi Boost - Manual - FM Intercooler - 3" S/Steel Plumbing
Super6 Injectors - Ceramic Wrapped Genie Extractors - 2.5" HiFlow Cat - 2.5" HiFlow Catback Exhaust with a 4" Dump Resonator
