Results 1 to 3 of 3
Thread: removing heater control
    VS 5.0 Ute
    Feb 2009
    Default removing heater control
    I have already posted about this in the air-con section, but wanted to cover all bases to see if anyone can help me with this one.
    am having trouble with the vent selector in my VS 5.0l ute. There seems to be a leak in the vacuum lines leading to the airvent selector. No matter what setting the selector is on it only blows out the feet vents. When I move the selector is hisses but doesn't stop or change the vents. I have looked at the vacuum lines and they all seem to be plugged in and un-broken, and the noise seems to be coming from the switch itself. My only problem is I can't work out how to get the entire switch assembly out of the car to service/replace it due to the metal rod that goes back from the heater switch to a white clip in the left of the drivers footwell. If anyone knows how to undo that without breaking it then I can fix the problem... cheers,
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    Turn the heater dial all the way to cold and pull the unit out of the surround as far as you can. The metal rod has a small 90* bend at the control unit end and a small plastic hook clips over the rod to keep them connected. Undo this clip and the rod will disconnect (the clip will be tight). Once the rod is out of the way it is just a matter of disconnecting the electrical plug and the grouping of vacuum hoses.
    VS 5.0 Ute
    Feb 2009
    Thanks for that, will give it a go when I get a chance...
  1. Climate Control/Standard Heater A/C Control
    By swift85 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-03-2009, 07:44 PM
  2. trac control button and heater control lights!
    By mrVT in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2008, 09:07 PM
  3. Removing the Heater Box?
    By HÝPÕ-5L in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2008, 08:52 PM
  4. Removing Heater Box/HVAC Box
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2007, 07:16 PM
  5. Removing AC/Heater controls
    By seabs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2005, 02:00 PM
