Hey guys,
I think this is my knock sensor but I wanna be 100%. Anybody shed some light on it?
I broke it sticking my arm in there, tightening my Sump bolts.
Any help wouild be great
Thank You
Ben.
There is no such thing as stupid questions, Only stupid people.
Look's like you are correct - knock sensor 'protected' by a heat shield. Only seen them with the engine out so I'm 90% sure. Book says remove the heat shield and undo sensor with a 22mm socket - catch the coolant. What a bummer.
Thanks Hako, Do you have a Gregorys for the engine/car? If you do any chance of you scanning that page and emailing me the pics??
Thanks mate
Ben
Also, anybody else no for sure this is the knock sensor?
Ben
Bump....... Sorta need an answer, I need get it soon, as i am dropping the crossmember soon and would be easy to do it all at once.
pm me your email - I'll scan the page.
OK - found your email in your profile and have sent the scan. I would have said I was 100% sure but I've had a few 'misses' lately and like to hedge my bets!
not many people here will have them as the hsv's were the only ones with them unless they were put in after. Sooo only that it looks like nothing on my engine i would have a guess its the knock sensor. Alternativly you could source a new tune/memcal that dosnt need a knock sensor so you can disconnect it and leave it out
Thanks Hako, You're awsome.
Oh ok, VrWagz, as i said i gotta drop the xmember so i may as well fix it. Thanks for your help
Ben
yer its a six guys, Thanks for clarifying that hakhawk.
Had a look that the pic and yer its the KS, Thanks again Hako
No problems and a pleasure to help. Your ride says it's a VS 3.8L so it's evident you've a V6.
ps...I'd better alter my ride to specify engine....slack eh!
my mistake, i assumed v8.
Looks like it has already been clarified but yes all ecotecs run two knock sensors, one either side of the sump. And yes that is your knock sensor in the photo protected by the heat shield.
