Results 1 to 7 of 7
Thread: drivers side rear window
    david41073 Guest
    Default drivers side rear window
    im having problem with the power window , ive been told it the window regulator, how much am i looking at replacing it and where would i find one, and is it hard to replace my self
    VR Berlina S2
    Apr 2005
    I've got the same prob :S I believe a window regulator is around $60 (going off prices at ozeparts.com.au) though through holden it might be a bit more... can't see it going over $100 or anything though.
    Not sure how much it would be to replace it, but if you do it yourself you basically have to:
    - *Disconnect Battery*
    - Remove door trim (by unscrewing the door handle and removing the snipper - then you carefully just pull it off from the bottom right)
    - Disengage and remove the glass (I did it to a VK once, real pain in the arse but I did it by myself. If I had help it probably would have been a lot easier)
    - Drill out the rivets holding the regulator in.
    Then just put it all back in. Personally, I'll be doing it myself
    BTW: If you buy or have the Gregory's service and repair manual, there's detailed instructions in there on how to do it. If you decide to do it yourself and can't get a hold of the Gregory's, lemme know and I can send you the detailed instructions on how to do it.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Are you sure it isn't the power window switch or relay...or dry glass runners. Not much to go wrong with a rear window winder which rarely gets used one would imagine. When you pull the door trim off, try connecting power straight to the window motor - if it works OK then it is not the mechanism.
    david41073 Guest
    it the actual cable that is fraying and making a grinding noise, and from holden $480, there is power to the window so its not the power
    VR Berlina S2
    Apr 2005
    david41073 Guest
    i think you have to get the whole electric window mechanism, inlcuding motor
    that price is supply oonly lol
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I repaired one from a Fairmont by removing the cable and replacing it with cable salvaged from a manual window setup - they are about the same length and you can get a manual winder from a trashed door at the wreckers for peanuts as they usually are unsaleable.
    Most cars have the cable setup nowdays so there are plenty around.
    Just about anything can be repaired.
  1. Drivers side window problem
    By onthepony in forum VL Holden Commodore (1986 - 1988)
    Last Post: 04-08-2008, 07:03 PM
  2. Drivers side window part.
    By epoxpro in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2007, 08:19 PM
  3. drivers side window stuck
    By azza009 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-04-2007, 05:34 PM
  4. Fitting drivers side window
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2006, 01:34 PM
  5. VT - Drivers side Window Issue...
    By bradwilks80 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-04-2005, 11:39 PM
