Results 1 to 11 of 11
Thread: VS CAI - won't fit due to tranny cooler hose
    VZ SV6
    Oct 2008
    Newcastle NSW
    Default VS CAI - won't fit due to tranny cooler hose
    Has anyone had an issue with the genuine holden CAI not fitting the VS (to ecotec) and any 'best method' solutions... the pipe that goes from the OTR duct to the airbox doesn't have enough clearance without putting pressure and bending the transmission cooler hose coming out of the radiator about an inch or so.... I'm thinking of putting a spacer under the airbox to raise the entire assembly and clearing the hose, but perhaps this might not make the duct fit properly over the radiator (bonnet closing etc)...
    anyone had any experience/ thoughts?? also is my cooler hose different from others... never heard of this problem before and all everywhere seems to say is "the supercharged CAI will bolt right onto the ecotec" etc etc....
    PS. i DID learn the hard way and think the cooler hose would survive but it didn't after a couple of days and pissed out fluid everywhere as it split at the clamp. quite embarassing
    Vy Sv8
    Jun 2009
    are you sure you got the right cai like i know the v8 one dont fit on v6 due to hitting on things
    aceventura's Avatar
    aceventura is offline Doesn't drive like this
    Mazda 6
    Oct 2008
    SEQ
    Quote Originally Posted by alex2_s View Post
    No this is normal. If you have a series I VS, you just put a longer length of hose on, you can go over the top of the duct pipe, which puts less stress on the hose. This is all that I did. From the thread linked to below, it appears that Series II models with the proper couplings don't have this problem.
    There is a better thread somewhere, this was the best I could find: (Fitting CAI to my car,trans cooler line???HELP PLZ!!)
    vr with ecotec
    May 2009
    mate i had the same problem with my ute with an ecotec and a supercharged cai. wouldn't work cause of the trans line. had to go and get a different cai for a v6 ecotec fitted no problem. the other thing you can do if your interested is marking the underside of the cai tube where the trans line wants to go through and then pull it out and heat it up. once you have it hot use a pipe and push it into it until you get the clearance you need.
    Changa is offline Alex Short
    VS Executive
    Jan 2009
    Hervey Bay, Queensland
    Yeha just go to autobarn and ask for the trans cooler pipe. Buy a length of it and then cut to the desired length so that there is more than normal so the cooler line can go over the top of the CAI duct. You lose a bit of tranny fluid so make sure you top up. Also do this when the car is COLD, so you dont burn yourself with tranny fluid.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I fitted the V8 one to my V6. No issues at all. It just had a big gap under the bottom where it would have sat on the fan shroud of the V8.
    You can just bend that pipe anyway, it won't hurt anything.
    Visit my Facebook page
    Vy Sv8
    Jun 2009
    Ok then i wont believe everything im told then thats the reason havnt fit my cai yet cos my mate said it wont fit cos its a v8 one.
    VS executive
    Jun 2009
    VR Series II S-Pac 5spd
    Jul 2008
    my brother just bought a vs wagon and the cai and is having the same problem and was wondeing whether could just get an elbow bend put into the trans cooler pipe im guessing this would be fine but just wanted to double check with someone??
    thanks
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It doesn't have to move far, just bend it. As long as you don't kink it, it will be fine.
    E46 M3
    Jun 2009
    as above, just allow the cai to push the pipe out of the way and sit against it, won't harm it at all
    mines been like that for years, not a problem
  1. vs trans cooler hose problem
    By supaushh123 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-02-2009, 07:39 AM
  2. Hooking up tranny cooler
    By Bz Kn33z in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2009, 03:55 PM
  3. Tranny cooler
    By Torquative in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-11-2007, 10:55 AM
  4. tranny cooler vk
    By purebitch in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-07-2005, 11:53 PM
  5. VP Auto Tranny Cooler/Warmer?
    By Jemahl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-11-2004, 07:18 PM
