Results 1 to 4 of 4
Thread: VR V6 auto dramas
    VS SS
    Mar 2009
    Default VR V6 auto dramas
    Hi all, have a bit of a problem with my VR Calais V6 auto, when it heats up to operating temp and i stop at lights or in traffic then go to take off, it wont select 1st, like its trying to take off in 4th, but if i select gears manually (if i put it in 1st), it will take off from what feels like 2nd gear. Anyone have any idea what could be causing this? Any help greatly appreciated thanks.
    woteva's Avatar
    woteva is offline NEED 4 SPEED
    VRII V6 Auto Wagon
    Jul 2005
    Adelaide S.A.
    Sounds like the same problem I sometimes have. It only happens to me if I have been driving uphill or through the city on a very hot day.
    http://woteva.tk/
    If it ain't broke... I can break it for you
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    You car is going into Limp Home Mode (LHM) which is designed to get you home with reduced power because the ECU has sensed a fault. In your case it may be simple like a stuck solenoid in the auto which I've had happen to me.
    In LHM, the car stays in 3rd gear when in D (reverse is also there), however you can manually select individual gears.
    You should do a codes check to find out what is wrong. Instructions are:Checking error codes VR/VS (Revised)
    Good Luck.
    VS SS
    Mar 2009
    thanks guys, i actually did an error code check a while back and nothing came up, ill check again tomorrow and see what happens......
  1. VR senator auto dramas
    By Disturbed_vegeta in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2009, 02:31 PM
  2. a few vz dramas
    By markovr in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-10-2007, 07:11 PM
  3. 202 dramas!
    By Joes_meat in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-05-2006, 11:58 PM
  4. air con dramas
    By VTPREDATOR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2006, 12:49 PM
  5. air con dramas!
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-01-2005, 10:18 AM
