Results 1 to 5 of 5
Thread: vs manual dash cluster
    2009 VE SS UTE
    Jun 2009
    Emerald
    Default vs manual dash cluster
    have a vs manual
    was wondering if possible to put an instrument cluster from a auto in it (has tacho where as manual doesnt), would there need to be any modifications, like extra wiring for the tacho that may not be there on my car?
    has anyone doen this?
    thanks
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    plenty have done this, no difference between auto and man clusters. Only difference is if its a v8 or v6 obviosly but the tacho can be modded to suit either one if your handy with a soldering iron.
    Reaper
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    All of the wiring required to operate the tacho cluster will already be there in your ute. There is no difference between an auto and a manual cluster, just as above I would recommend sourcing it from a vr/vs that has the same motor i.e v6 or v8 so that the revs read accurately. Its then just a matter of removing the existing cluster and replacing it with the new one and it will work fine.
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    A manual cluster has no tacho but an auto does...? Who was the brains behind that?
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    its not a case of manual auto.. its the series.. not all utes had tacho's most of the manuals i saw in the wrecking yard didnt have a tacho. depends what was optioned from the factory as well
    SIR LS1
    the two ton go kart
  1. [VIC] FS: VN V8 BT1 dash cluster *low kms*
    By calaiscruzer in forum Parts And Other Items For Sale
    Last Post: 31-05-2009, 10:25 PM
  2. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  3. VT Dash Cluster
    By Sparkie in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-01-2006, 08:23 PM
  4. Help With Dash Cluster?
    By vs ss ute in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-08-2005, 07:23 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
