Results 1 to 6 of 6
Thread: My car has a ghost!
    VS executive
    Jun 2009
    Default My car has a ghost!
    my heater fan has been playing up lately , working when it feels like it and also my demister would not work and often shutoff the fan when i pressed the button.
    today with the air going i turned the car completely off and the air kept blowing, perplexed and not wanting somthing bad too happen i opened the bonnet and removed the fuse marked `blower` which stopped the fan ... went off and did my thing.
    when i came back i put the fuse back in and low and behold everything works again, demister, aircon , fans ........ so does this tell me anything needs too be replaced or should i just leave it and see what happens?
    whitey152's Avatar
    whitey152 is offline cruzen
    1996 vs berlina
    Jul 2008
    port macquarie
    yeah mine kinda does the same turned aircon off and ignition off and it keeps blowuing air so had to take out the blower fuse id like to know y lol
    but mines climate control
    VS l67 statesman
    Dec 2008
    I had VP And Vl with central locking ,and when water gets in the wiring from either washing the car or heavy rain ,the door buttons go beserk opening and closing at random sometimes for hours .I have notice this also happens when the battery is low on charge ,so this migth be the same cause of your heater problems
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    The heater fan iussue is because of a dodgy resistor. There is a how-to on how to fix it somewhere on this site.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Sounds like a dodgy blower relay with burnt or dirty contact which don't open when the relay is de-energised. This will also cause intermittent operation as the dirty/burnt contacts cannot always make proper contact. . It's located with the other relays under the bonnet near the battery and marked "blower". Either swap with another nearby relay of the same size (temporarily) or replace. If you are real keen you can prise them open and clean the contacts.
    VS executive
    Jun 2009
    ive tried 3 different blower relays and same thing , i noticed theres a 2.5a fuse there aswell which ill try next.
LinkBacks (?)
  1. 26-08-2009, 10:22 PM
  1. Ghost Brakes
    By Joe_222 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2009, 04:11 PM
  2. Ghost in the electrics
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-02-2009, 02:14 PM
  3. Ghost posts
    By walesy in forum Site Feedback / Site Problems
    Last Post: 16-01-2007, 06:56 AM
  4. ghost lights ????
    By surfindude in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-08-2006, 05:12 PM
  5. Ghost In vp Speedo ??
    By vpgirl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 11:30 AM
