People have been saying to perform an error code check if you think something is wrong with your car.....how do you dont that? dont you need a scan tool?
use a paperclip and bridge pin 5 and 6 , light the ignition (do not start) and read the codes, (themo fan runs if done properly)
code's blink 10's and 1's with a small pause (a larger pause indicates a new code) reapeting the 10's and 1's
Just Commodores - For All Your Holden Commodore Needs
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
Thermo fan doesn't run on the VS.
Each code will display three times starting with 12 and ending with 12.
Thermo fan does runs on mine. See link below and follow other embedded links to extra info
Checking error codes VR/VS (Revised)
Mine never did, and the two other VS's I have checked didn't either. The VN we have does though. All V6's though.
Might be a V8 thing then?
havent done much searching have we lol. theres about twenty threads on here that tell you how to do it
and yes on my 5L the thermo switches on when i do diagnostics
SIR LS1
the two ton go kart
yip V8 runs the MAP based ecu may make a difference to the fan ide say
