gday
i have installed a cigarrete lighter adapter in my boot so i can a fridge in my boot. i have spliced my power from the boot light and earthed it on the boot. it runs fine but my mate says that thw wire cant carry that much current and the wire will overheat. surely if the cigarrete lighter on the console can a fridge fine wont this one?
thanks in advance
never had that problem before and ive had the ciggie in the boot since 1990
really depends on how much current the fridge draws
48 watts it uses
i used the same sized wire as the cigarrette lighter in the center console
also draws 4 AMPS
bump bump bump
It should run fine, i have 3 neons hooked up to my boot light, plus the boot light, which light up when i open the boot, nothing wrong with it. It may occasionally blow but a fuse is only like 40c each.
fuses dont bother me
im just worried of overloading the wire and burning out my loom
I wouldn't power that off the light switch. would run a dedicated wires from the battery, your fridge had an auto cut off if the voltage drops yes?
-Smit
ok if i ran it directly from the battery, what amperage fuse should i use?
the fridge uses 4 AMPS at 48 watts
