Results 1 to 4 of 4
Thread: 95VS statesman headlight problem
    VS Statesman
    Jun 2009
    Brisbane south-side
    Default 95VS statesman headlight problem
    As a new member I would like to say hello to all, and say thankyou for all the information that has been posted here. By using the info here I was able to get the most out of my VR untill it was written off a couple of months ago. I now have a 95 statesman with the following problem. I have searched but have had no luck with a answer, hopefully someone may have had a similar fault.
    It started a few weeks ago with the passenger side headlight going off, when I moved the bulb to replace it the it worked, it did it a couple of times over the next week. I then removed and checked all the conections, fuses, relays etc I could. Now the light has stayed on, but when you remove the fuse for a headlight, the headlight dims and the high beam lights (centre 2) glow dimly. Both sides behave the same.
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    sounds like the plug might be loose or dirty, and if it the high beam globe, might not be eathing properly.
    the lights dimming and the high beams coming on dim isnt a problem, its just the way the system is setup.
    VS Statesman
    Jun 2009
    Brisbane south-side
    Thanks for the reply. I have checked all those but will check them again more closely.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Also check the high and low beam relays, particularly the earths at the relay as this is where the bulbs earth.
  1. headlight problem
    By v8's rule in forum Electrical Wiring / Questions
    Last Post: 26-03-2009, 12:17 PM
  2. [VIC] WTB need vp calais/ vq statesman headlight-dimmer switch
    By hi_ryder in forum Swap / Wanted to Buy / Trade
    Last Post: 02-12-2008, 07:40 PM
  3. VC Headlight problem?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-05-2008, 08:16 PM
  4. vs headlight problem
    By CynisteR in forum Electrical Wiring / Questions
    Last Post: 13-09-2005, 11:00 PM
  5. Headlight problem
    By ryan_VL in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-09-2005, 12:59 PM
