Results 1 to 8 of 8
Thread: Installing VS cruise control - no loom
    VS ii
    Apr 2009
    Lightbulb Installing VS cruise control - no loom
    Okay...
    I want to install CC on my VS series II.
    To my horror, it doesn't have the wiring loom.
    There are several bits and pieces of good info around the forum, but it is so messy and mixed and then people always chime in with their own problem and the thread goes to something else.
    It seems like a very common problem/project, so I thought it would be cool if we could get a proper once-and-for-all thread going.
    Once I've learned how to do it, I could go through the whole process and take pics while I'm installing it and then posted it all up.
    Anyone who has the VS factory instructions would be a true gem.
    I guess we need to start with a list of components that we need...
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Markovr put the factory install pages (10 in total) into a thread not long ago. There is a factory patch loom from Holdens one for the engine bay and 1 for the cab under the dash.
    This is a photo of the part numbers:
    http://forums.justcommodores.com.au/...ruise-loom.jpg
    and 3 Dangerous non ABS VN's
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Yes I did here but the instructions are for a vr most components are the same but the cable end at the throttle setup is different for a ecotec(vs) to the buick(vr) and I have the vs type loom to sell if it interests anyone as the 2 part numbers mentioned in shanes post above.
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Cobra Clutch View Post
    Okay...
    If it's a series 11 VS it 'should' have the wiring loom. What makes you think it doesn't?
    I recently installed factory CC to my VS series 11 and it was "plug and play".
    VS ii
    Apr 2009
    Quote Originally Posted by hako View Post
    Its an Executive.
    The reason I think I it doesn't have it because it is not there.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Its an Executive.
    I'm not trying to put you on the spot - just trying to help. If you think it's not there then OK.
    Mine is an Executive as well - and all the wiring was there. Have you checked near the pass side spring tower for the multi-pin plug, and under the steering wheel where the relays are check the CC relay spot has wires behind and also near the brake switch there should be a spare 2 wire plug for the CC brake switch.
    There are pix of where to find the plugs etc at:
    How do I install genuine cruise control on a vs executive?
    Nov 2003
    northside brisbane
    Here is a diagram of the wiring
    VS ii
    Apr 2009
    Yeah, its all good, its so many people keep asking me, and as odd as it is, given its a 97 model too, there is no wiring.
    I have a series III ute with CC so I know exactly what it looks like and where it is. I was so confident that I bought the CC without even looking.
    Oh well, I'll it put down as another notch on my car maintenance degree...lol
  1. VN And VP Cruise Control Patch wiring loom... are they the same?
    By speedyvn in forum Electrical Wiring / Questions
    Last Post: 26-04-2010, 08:22 AM
  2. [WA] WTB VR/VS V8 cruise control loom/harness
    By undar8ed1 in forum Swap / Wanted to Buy / Trade
    Last Post: 31-01-2009, 12:50 AM
  3. installing cruise control
    By Snotty_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-08-2008, 04:51 PM
  4. Installing Cruise Control...
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-09-2007, 11:33 AM
  5. Installing Cruise Control???
    By holdensupporter2005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-10-2005, 11:34 PM
