hey guys i have a 95 vr wagon,latley the drivers door has been a little sticky 2 open(as in u have 2 pull the handle 2 or 3 times to get it open) and today i shut it and it stayed a jar as if a seat belt was caught but it wasnt and after jamming my key in the mechanish and getting it open i slammed it a couple of times and it closed properly....anyone know what the problem would be???
ya needs adjustment on the latch locker (thingy a bobby) on the body. also remove the door trim and hit it with sum crc or penetrene
Take the door trim off and spray all the rods linkages etc with wd40 this will help free them up then spray them with chain lube. i suggest chain lube cause it will stick and do its job, wd40 silicone spray etc will just wear off.
alrite,thanx 4 your help guys ill give her a go over the weekend![]()
