Results 1 to 11 of 11
Thread: vr brake upgrade
    aphexcloud is offline mech
    vr v6/5.7l wh statesman
    Sep 2008
    Default vr brake upgrade
    Hi All
    have had a quick loo around the forums and couldnt find anything the stood out so if this has already been covered please link the thread.
    i am doing a v6-v8 conversion and would like to up grade the front breaks,master and maby the booster dependong on that is wrong with the systemi have a leaky master and instead of just a straight replacment i thort i would go down the path of an up graded one so if any one knows any brands/part numbers that make better masters that suit a vr.
    I also am looking at upgrading the front breaks and was wondering if any one knows a good after market brand of what model commo that has good breaks that will suit a vr
    break and rotor size sint a problem as i havent bought wheels for it yet and am cinda scaling the wheels to suit the breaks.
    also if any one had vr v8 cluster lowered shocks and super low springs they want to get rid of pm me maby we can sort somthing out
    thank you in advance
    Ps: sorry for the little to no punctuation and bad spelling i am dislexic
    VS Commodore series II
    Mar 2009
    Port Macquarie
    people say upgrading to vt brakes, tbh i have no idea why and dont know if they fit vr im sure they fix vs so why not? but anyway thats something ive heard also i might be able to get v8 super lows for the front if your interested
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by Silver_VS_II View Post
    Because they have two pistons instead of one, and they have both a bigger caliper and a bigger rotor. They have much more stopping power than the VR/VS standard brakes. You can get a kit from Holmart with everything you need for roughly $400. Hopper's Stoppers (I think thats the name) in Hoppers Crossing did have a VT brake kit at one stage. They do a fair bit of brake upgrade work to, so you might want to check them out.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Vt booster m/c in Vr V8 with ABS
    How To - VT Brake Upgrade
    Pm markovr, he makes the vt master/booster setup with adaptor bracket to suit vn-vs all complete and posted to you for a reasonable price. thats if you dont wanna make it yourself using the instructions in the links.
    Its up to you if you wanna buy a upgrade kit off someone or source some second hand front rotors and calipers off a VT-VZ for as cheaps as you can and see a brake shop for some new longer brake lines. The hub rings you can getoff ebay for about $40.
    Reaper
    Sep 2008
    cheers vrwagz1 going to be getting one of the booster/master setups from him soon
    Jun 2005
    just grab some VT rotors, calipers, master cylinder and booster. should set you back $300-500, but its a great upgrade. or else you can look into a VE upgrade kit for around $800
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The VE upgrade kit comes with 322mm slotted and dimpled gold passivated rotors, new VE calipers, new braided brake lines, new pads, brake fluid and the mounting hardware. I do them closer to $700. A set of slotted rear rotors if you want upgrade the rear is really all the is needed back there.
    Visit my Facebook page
    Mar 2009
    Port Macquarie
    Quote Originally Posted by _R_J_K_ View Post
    cheers mate thats interesting to know
    VS Executive V6 Auto
    Dec 2007
    Newcastle
    I just got a pair of front VT rotors, calipers and adaptor shims to put on my VS V6 Exec.
    However, I also want to install braided hoses while I'm at it. Do I need VS, VT or custom hoses?
    Where do people recommend getting braided hose from?
    Another thing the Gregory's manual says, 'Note: The caliper lockbolts have special locking compound on the threads and therefore must be renewed if removed'. Have other people done this?
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by mcvk View Post
    You need custom ones, Just go to a local brake shop and ask them to make you some. They basically need to fit the fittings for the vr factory brake piping on one end and at the other end the fittings for the vt caliper and overall the hose is longer. At a pinch standard vt hoses will adapt and screw into the vr but on full lock they kink
    Reaper
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by aphexcloud View Post
    There is a how-to to convert the tacho on the v6 cluster to be v8 compatible in the How-To section.
  1. How To - VT Brake Upgrade
    By vsiicalais in forum Holden Commodore How-To's
    Last Post: 26-09-2011, 08:32 AM
  2. VT brake upgrade
    By Philthy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2009, 11:55 PM
  3. Spongy Brake Pedal after VT Brake Upgrade
    By DJ Ice in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-01-2008, 08:48 PM
  4. brake upgrade
    By StatOmaN in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2006, 10:05 AM
  5. VN to VS V8 Brake Upgrade
    By vinnywelsh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 01:46 PM
