Results 1 to 7 of 7
Thread: ignition barrel worn out.... questions...
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    Exclamation ignition barrel worn out.... questions...
    ok well my car needs the key to start...but the ignition barrel is so worn out you can just pull the key put atany given time.
    so how do i fix this??...it wont start with anyother key or object etc... but you can be driving along and just pull it out...throw it out window if ya like and the car still goes....
    can i buy another barrel insert and use the same key or...??? i dunno... how do i fix this???
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Default we have the technology
    It will need replacing, quicker the better or one day soon the ignition will not turn. To do this you need to find the small hole on the outside of the barrel housing and innsert a paperclip in there while you have the key in on postion and the barrel just comes out when you pull the key out.
    Also check out my HOW TO GUIDE for more ifo including a DIY guide for creating the barrel to suit your key.
    How to remove a stuck ignition barrel VN-VS
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    You can buy another barrel and have it set to your key.
    MY RIDE
    Feb 2009
    where can i get it set to my key????? and also...when i pull the key out and the barrel is supposed to comeout with it........that wont be happening...cause just the key will come out...
    VS exec
    Jun 2009
    bong from the gong
    Take it to a locksmith not those key cutting stores you see in shopping cetres
    VR Executive S1
    Mar 2009
    A Locksmith will give you a new ignition barrel, same thing happened to mine but i kept using it until the ignition swith broke had to get this guy from the locksmith out and replace it cost about $160 all up.
    Vr Executive 3.8
    Dec 2008
    Yeah get it changed asap so you don't get stranded, happened to me lol. It cost me 250$ to have it replaced but that was more expensive because the locksmith had to come out on a Saturday. Takes them no more than 20 minutes to do
  1. ignition barrel
    By 235rwkw in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-11-2007, 07:26 PM
  2. Ignition Barrel
    By Vk_stock in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-03-2007, 12:32 AM
  3. ignition barrel
    By adam69 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2006, 10:50 PM
  4. help! car stuck, worn ignition barrel cant turm
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-04-2005, 12:03 PM
