Results 1 to 6 of 6
Thread: Any Ideas.........
    mrhotdog is offline What Would Jesus Do?.....
    2003 VY S1 Acclaim
    Nov 2007
    Adelaide, South Australia
    Default Any Ideas.........
    Hey all
    I have two qns
    1. went over a big bump yesterday, now the fan doesnt come on when you press the air con button, dont know if its related
    2. When i brake just before you stop you can kinda feel a clunk motion; the sway bar bushes are only about 6-8 months old, what else could cause this?
    cheers
    Originally posted by TVR-161
    " they dont have probs caz da cop chip is better den da normal chip yo, it makes shiz work"
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Your first question I'd hazard a guess and say you've punctured your A/C condenser in front of the radiator and the gas has escaped - this then actuates the low pressure switch preventing the A/C compressor operating and the fan. Check by unscrewing a cop off one of the gas connectors near the dryer and press the tit - you should hear gas escape - if not you have no gas.
    Number 2 - wheels stud nuts not loose?...otherwise I'd say the lower control arm bushes.
    2003 VY S1 Acclaim
    Nov 2007
    how could i have possibly punctured the condensor, its not like i hit a stake or anything lol, could it possibly be a relay or fuse, and can i swap any to test? thanks for the reply
    2003 VY S1 Acclaim
    Nov 2007
    well hako it looks like u were right, took a plastic cap of the pipe closest to the radiator, and no gas at all, so next step, does the condensor need to be replaced or is it a fixable part? and can it be DYI or would a proper place have to do it?
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    i'd suggest taking it to an auto elec or an auto aircon place and get them to leak test the system, incase its not the condensor. They have a common problem with the connection to the tx valve coming loose, and, if the aircon hasnt been touched before chances are the fittings at the drier will be siezed and/or just fall apart
    2003 VY S1 Acclaim
    Nov 2007
    ive had the air re-gassed once, but nothings been touched as long as ive had the car about 18 months now
  1. 5L Ideas
    By .Holdon. in forum V8 Development and Modification
    Last Post: 21-11-2008, 05:48 PM
  2. VT air con ideas
    By craigvk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-04-2007, 08:09 PM
  3. VC.. mod ideas?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-05-2006, 09:13 AM
  4. Its been a while, new ideas.. :)
    By thesilverskull in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-05-2006, 06:49 PM
  5. any ideas??????
    By lilkel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2006, 06:26 PM
