Results 1 to 17 of 17
Thread: no pulse from the injectors URGENT please help
    VS V8 Berlina Wagon
    Jul 2006
    Default no pulse from the injectors URGENT please help
    Hi all
    I hope someone can help , the other morning I went to start my car and all it would do was crank over, so I checked for spark, that’s fine, checked for fuel and that’s fine, checked for injector pulse, no go, so I jumped on the forum and did a search found shits loads of info and a few conflicting ones, so in the mean time I have replaced the coil, ignition module , the relevant relays but still nothing, I was reading that the dizzy and/or the bcm can cause it, has anyone had any success with replacing these? Ive checked for fault codes and all im getting is code 12.
    Has anyone got any suggestions one what else it can/could be ?
    cheers
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    If you have no injector pulse your security may not be disabeling, is the red light stopped flashing when you try to start the car.
    Also are you sure you have no injector pulse, or have you no fuel pressure.
    Reaper
    VB SL/E
    Dec 2008
    Yeah, as above check the security and if the relay is clicking (getting power).
    VS V8 Berlina Wagon
    Jul 2006
    yeah ive checked the fuel pressure and thats fine, i havent really payed much attention to the security light, so im guessing if it is still flashing when i try and start the car it means the disable feature isnt being disabled?
    is there anyway of resetting it ???
    VS V8 Berlina Wagon
    Jul 2006
    well i checked the security light and it turns off when i turn the ignition on, im gonna replace the dizzy either monday or tuesday just to rule that possibility out
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    how are you checking for injector pulses.check theres 12 volts at the injectors cause the ecu earths the injectors to fire them
    VS V8 Berlina Wagon
    Jul 2006
    VX II SS Ex Chaser V8
    Jul 2005
    From the circuit diagram the only thing stopping you would be the EFI relay or the ECU. !! Fuse 25 not only powers the injectors but the Ignition Module so if you have spark it's not that either. I don't think the dizzy would stop the injectors from firing, although they use the same fuse??
    When everything's coming your way, you're in the wrong lane.
    VrWagz1's Avatar
    May 2008
    wollongong
    Quote Originally Posted by Asmodai78 View Post
    with a multimeter, im getting power on both sides
    then they should be fine, if they are powered then the ecu simply earths them out when the need to pulse, which your multimeter may not pickup. Pull out the rail its only a couple easy bolts and see if they are squirting when you crank it.
    Reaper
    VS V8 Berlina Wagon
    Jul 2006
    ok i pulled them out last night and they are not squirting when i crank it, im getting 12v on both sides still, ill try another ECU today before i change the dizzy, ill let you all know the outcome
    VrWagz1's Avatar
    May 2008
    wollongong
    If you can get one thats not a good idea. Its either broken or not firing them for some reason.
    Reaper
    VS V8 Berlina Wagon
    Jul 2006
    VS V8 Berlina Wagon
    Jul 2006
    ok well i put another ECU in from a known working car and still nothing, so its all still pointing to dizzy and BCM
    does anyone know how much a BCM might cost?
    VrWagz1's Avatar
    May 2008
    wollongong
    vr vs commodore bcm/key/locks - eBay Other Interior, Interior, Car Parts, Accessories, Cars, Bikes, Boats. (end time 25-Jun-09 18:53:47 AEST)
    Heres a kit from ebay, and it includes everything. Which is handy cause your key wont work with the new bcm. I'd steer clear of doing this unless its a definate diagnosis on it.
    Reaper
  15. #15
    VS V8 Berlina Wagon
    Jul 2006
    Thanks for your help VrWagz1, i was looking at that last night, it might be a good idea to get it if the dizzy replacment dont work at least ill have more bases covered.
  16. #16
    VS V8 Berlina Wagon
    Jul 2006
    well just a follow up on this topic for future ref, i replaced the dizzy and the wagon started up first go, so it was the dizzy all along, the Hall effect sensor was stuffed so the computer didnt know when to fire the injectors.
  17. #17
    VrWagz1's Avatar
    May 2008
    wollongong
    awsome man
    Reaper
  1. Cluster - Con 2 - Pulse GND/2 Pulse shorted, now no speed
    By VS Omega in forum Electrical Wiring / Questions
    Last Post: 16-02-2009, 09:37 PM
  2. Cluster - Con 2 - Pulse GND/2 Pulse shorted, now no speed
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2009, 12:11 AM
  3. Vp pulse divider
    By metlhead666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2008, 02:20 PM
  4. WANTED URGENT!!!! VL Turbo ECU and Injectors
    By eko in forum Swap / Wanted to Buy / Trade
    Last Post: 09-09-2008, 05:35 PM
  5. Need help! no pulse
    By minimefx in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-04-2006, 08:48 PM
