Results 1 to 6 of 6
Thread: fuse help
    vr berlina
    Mar 2009
    Default fuse help
    i need a bit of help my car is currently broken down about 250 kays away from where i am now i plan on going up to fix it soon but i need to know if it is a fuse for my 02/maf sensor or a relay and what volt/model number just wanna get it before i go so im prepared
    VX II SS Ex Chaser V8
    Jul 2005
    Well, either the fuse is blown or not, your question is a big ask, it could be anything man.
    When everything's coming your way, you're in the wrong lane.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    if its o2 then i dont think it will cause your car to stop, unless its shorted out and blown a fuse, in which case find the fault and replace fuse. IF you dont beleive you have a fault then to get you out of a tight spot a paper clip in the fuse holder connections can make a nice quick fix, BUT it will not blow if there is a fault and you may cause more damage to your wiring and possibly set your car on fire. Why not just rob fuses from spare ccts like your lights, cig lighter or radio fuses, im sure you could limp somwhere without them functioning.
    All relays are 12 volt just different current ratings, again why not just rob somthing like your high beam, horn, or low beam relay or somthing to swap with whichever one you beleive to be dead.
    Reaper
    vr berlina
    Mar 2009
    thank you for those who replyed but didnt help in anyway since it has nothing to do with my question
    VS exec
    Jun 2009
    bong from the gong
    Quote Originally Posted by buster1192 View Post
    buy a pack of assorted fuses from repco, ask them for the correct relays they will have a book and look it up and tell you what one you need.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    ^^ what he said.
  1. VR Fuse #1
    By XLR87N in forum Electrical Wiring / Questions
    Last Post: 12-01-2009, 12:29 AM
  2. USE a FUSE
    By coo dawg in forum Electrical Wiring / Questions
    Last Post: 22-08-2008, 06:58 PM
  3. VX fuse
    By dcamo50 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2005, 07:14 AM
  4. Fuse Box
    By Hgprem01 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-07-2005, 09:35 AM
  5. fuse box
    By Davin VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2005, 11:20 PM
