Results 1 to 22 of 22
Thread: why doesnt my thermo fan turn on when i press the a/c buttor vs calais
    Oct 2004
    Default why doesnt my thermo fan turn on when i press the a/c buttor vs calais
    hey all why doesnt my thermo fan turn on when i press the air con button in my vs calais??
    social's Avatar
    social is online now Ute Finatic
    MY06 6.0L VZ Thunder(na naa na naa..)
    Nov 2008
    South Aus
    because a thermo fan is supposed to only turn on once the engine has reached a certain temperature (eg 1/2 way on the temp guage) to cool it down... its not button operated ALTHOUGH you can edit it to be so..
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Quote Originally Posted by scottmcguinness172 View Post
    It works like this with standard air-con. I believe that climate control will control it differently.
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Mine turns on wheni hit the a/c button
    Reaper
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    VT spac super6
    Nov 2008
    Riverton sa
    the fan will always operate with the a/c on
    does the a/c actualy work? check that the compressor is kicking in mate
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    VYII Acclaim
    Jun 2008
    Quote Originally Posted by Social View Post
    Umm, WRONG! If you have a service manual.... READ IT!
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    The interior fan also has to be turned on for the AC to operate, which should start your cooling fan.
    Oct 2004
    the engine fan cuts in at 3/4 but when i hit the a/c button on the climate control and turn the temp to as cold as possible the air con compressor doesnt kick in i dont think but i know for sure the engine fan doesnt kick in when i turn the a/c on
    greenacc's Avatar
    VE Berlina
    Jul 2008
    Is your air con cold ? And does your engine fan work on both high and low speed ? Maybe your low speed relay is caput, as this should switch on at 1/2 way on the temp gauge, and high speed about 3/4. Try swapping the relays around in the fuse box in the engine bay and try again.
    VT spac super6
    Nov 2008
    Riverton sa
    Quote Originally Posted by scozz76 View Post
    one fan operates with a/c
    engine fans come in at just over 100degrees
    Oct 2004
    im not sure about low and high speed but i know the engine fan comes on at 3/4 i thought they come on at that temp in an ecotec?? no the air con is hot it just blows air no cool air i dont think the air con compressor clutch is coming on ill have to check when i get home
    greenacc's Avatar
    VE Berlina
    Jul 2008
    I can only speak for my car, but my low speed fan comes on at half way on the gauge, and high speed at 3/4 and i think this is how it should be. Try swapping or replacing the low speed fan relay.
    Another minor detail is to check if the little green light in the AC switch comes on when you press the buttin. If not maybe its just your switch that is rooted !?
  15. #15
    VT spac super6
    Nov 2008
    Riverton sa
    from memory the light will still go on, even when the compressor doesnt kick in
  16. #16
    94 VR Calais V8
    Aug 2007
    Sydney, NSW
    In order to get the correct answer, please indicate if its a V6 or V8 calais.
  17. #17
    Oct 2004
    it is a v6 ecotec vs calais when i hit the a/c button on the climate control the little a/c icon comes up on the display on the screen
  18. #18
    VYII Acclaim
    Jun 2008
    It sounds like your a/c is low (needs re-gas) There's a pressure switch that stops the a/c from turning on if the pressure is low. It's a safety feature to stop you from running the system dry. I've previously bypassed the switch (on a ford) for testing purposes but only ever for a split second.
  19. #19
    Oct 2004
    hey all i just checked if my air compressor kicks in and it doesnt i checked all the fuses and the fan still doesnt come on anymore ideas??
  20. #20
    greenacc's Avatar
    VE Berlina
    Jul 2008
    maybe the compressor clutch is dead, or its an electrical problem and its not getting power to it ?
  21. #21
    mrhotdog is offline What Would Jesus Do?.....
    2003 VY S1 Acclaim
    Nov 2007
    Adelaide, South Australia
    same prob has happened with mine recently, gas just disappeared, hako suggested it might be the condensor or the lines, but im gettin it looked at in the next few days or so, its only an exec but i think the idea is the same
    Originally posted by TVR-161
    " they dont have probs caz da cop chip is better den da normal chip yo, it makes shiz work"
  22. #22
    Oct 2004
    hmmm i dunno i was talking to my mate he is a fridgy he is going to regas my aircon this week and check it out for me so ill wait and see what happends
  1. vs calais ecotec thermo fan not working
    By scottmcguinness172 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2009, 07:16 PM
  2. VX CALAIS headlight auto turn off
    By Switta in forum Electrical Wiring / Questions
    Last Post: 09-04-2008, 01:25 PM
  3. VP Calais, Thermo Fan Help
    By slipstream001 in forum Electrical Wiring / Questions
    Last Post: 09-10-2007, 03:15 PM
  4. press remote once driver door up press again back down wtf
    By jarred193 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2007, 10:35 AM
  5. VN Calais Wont Start but will Turn over
    By mrhaboobi in forum Electrical Wiring / Questions
    Last Post: 20-09-2005, 09:18 PM
