Results 1 to 16 of 16
Thread: Water in boot
    VB SL/E
    Dec 2008
    Default Water in boot
    I have water in the boot all over the floor, not just in the wheel well.
    Is there another common cause besides this How To Fix A VN-VS Boot Water Leak
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Could be the boot seal or the tail lights too.
    Visit my Facebook page
    E46 M3
    Jun 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    And where the number plate bolts to the boot plus the garnish trim either side.
    VB SL/E
    Dec 2008
    ^ Yeah garnish trim looks sus.It has broken mounts each end. I will try fixing it, also might try removing the boot seal, cleaning that and removing the tail lights for a look and mounting the garnish better.
    Thanx guys.
    VB SL/E
    Dec 2008
    When I posted I searched and only found the thread I listed above but after retrning to the thread, at the bottom was four relevant threads?
    What gives with the searches?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by VR38 View Post
    I think whatever generates the "similar threads" at the bottom of the page uses much more clever search techniques than us lesser humans. I find it turns up better threads than you can find doing the search yourself and usually will provide the exact answer to the query.
    Maybe it's all done with mirrors.
    the collector is offline the collector
    rodeo dual cab
    Mar 2009
    adelaide
    Default leaking
    has your car been hit in the rear before?
    bar bolt holes
    tail lights
    boot spoiler
    rear windscreen rubber/rust/poor install
    any body join
    suggestion: remove everything from boot,dry everything,get a torch,get a hose,get a mate,one gets inside with torch and mate gets hose and hoses car gently but consistantly all around the rear of the car while talking to boot guy and telling him where to look for leaks.
    this is what a crash shop will do for you
    good luck
    cheers
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    They sell crashes in shops?
    Slippy_Trippy is offline Unicorn Shepard
    1999 VT II Commodore Acclaim
    Jun 2009
    Melbourne, VIC
    My boot leaks too, only when I open it though . Stupid VT boots. They drip on your stuff and don't even get me started on the struts
    -Slippy
    VS Berlina 3.8
    Dec 2008
    Are you using Google?
    For those that don't, I find Google turns up a lot more results. For example, type this into the google search bar -
    "water in boot site:forums.justcommodores.com.au" (without the quote, obviously).
    That "site:" bit limits the search to the site that you put in.
    VB SL/E
    Dec 2008
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by _R_J_K_ View Post
    +1 this is some really good info
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    3.8L S1 VN
    Stick Avalanche Champion!
    Jun 2009
    latrobe valley
    im having the same trouble with my vn, my whole boot gets drenched.. apparently it comes from the windows or something.. dunno if its the same as the link in the first post.. but yeah, any help?
  15. #15
    VS S2 Acclaim
    Apr 2005
    It comes from the rear quarter window. There is a thread which instructs you how to repair.
  16. #16
    Chirpstr's Avatar
    Chirpstr is offline A new project attack
    VR Berlina M5, VP M5
    Sep 2007
    Check the fuel flap hinge gasket too.
  1. Water in Boot
    By Rodeo058 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2009, 09:11 PM
  2. Water in boot Lid
    By G4orce in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-12-2008, 07:40 PM
  3. water in boot
    By dale s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2006, 01:21 AM
  4. Water in VS boot lid.
    By SunCoastSister in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2006, 02:06 PM
  5. VS - Water in boot lid.
    By pod in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2004, 09:48 AM
