Results 1 to 5 of 5
Thread: Another vs auto problem
    vr with ecotec
    May 2009
    Default Another vs auto problem
    I have read so many threads on vs autos and still with no out come have i found my problem. Ive checked the fluid level Ive checked the codes and every thing is telling me its normal yet it is slipping from 1st to 2nd and 2nd to 3rd can can one help with this problem?
    Wherry951's Avatar
    Wherry951 is offline PROJECT UNDERWAY
    VT S, V6 5 Speed Manual
    Jun 2009
    Sunshine Coast, QLD - The Defect State
    Clutches inside the box are probably worn. Being a kinda cruisy car of such the box tends to change gears by sliping the clutches so it gets a smooth change. If its not that check your solenoids.
    Im not a mechanical genious at 17 tho so maybz get others opions as well. I did a quick look on the internet for you and thats all i could come up with tbh
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Yeah, The codes are only going to come up with anything if the sensors pick up a fault, so if it isnt coming up with anything, it probably thinks everything is ok. The solenoids if they fault will generally make an error code, so my guess is the automatic clutches are worn out, there isnt a sensor to tell you that.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If the trans has done over 200,000km it's near the end of it's life unless well looked after. Check the colour of the oil - if brown it's due for a change/service. Clutches will wear, valve bodies get sticky, filters get clogged....all signs of old age.
    It is possible to add some 'trans fix in a can' - this can make the clutches grip better and will give you a few more miles before overhaul as long as you don't abuse it.
    VS exec
    Jun 2009
    bong from the gong
    As hako says you could try replacing the oil and add a can of trans fix or what ever they call it might help fix the problem would also be worth while adding a trans cooler.
  1. VR auto problem
    By rodney3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2009, 08:03 PM
  2. vp auto problem
    By markovr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-12-2007, 10:58 AM
  3. problem with auto
    By KingCoMMoDore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-02-2006, 08:34 PM
  4. problem with VR V6 auto
    By krizko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-03-2005, 09:25 PM
  5. VY auto problem
    By keithVYSS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 14-10-2004, 11:11 PM
