Results 1 to 18 of 18
Thread: Exhaust
    VB SL/E
    Dec 2008
    Default Exhaust
    I am trying to track down what would overheat my exhaust, engine temp has been a little low (will change the thermostate soon) and te O2 sensor is faulty, would this be the cause or is there other faults that commonly cause an exhaust to run too hot?
    E46 M3
    Jun 2009
    VB SL/E
    Dec 2008
    It is not running hot, it is OVER HEATING. there is spots on the mufflers where you can see it has been glowing red hot.
    When the exhaust shop replaced my middle muffler today he said he had never seen one get soo hot.
    even after he cut it out and it was sitting on the floor for 10 minutes it was still too hot to touch by hand.
    No more stupid comments please.
    If an exhaust shop says it is too hot then it is running TOO HOT.
    VT spac super6
    Nov 2008
    Riverton sa
    It can take over half an hour for a muffler to cool down after its been on a car mate..
    the hot spots arnt just tig weld marks right?
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by VR38 View Post
    Have you checked your error codes?
    Good chance that's it. If your engine is running lean, it burns hotter (or is that rich?).
    VT spac super6
    Nov 2008
    Riverton sa
    VB SL/E
    Dec 2008
    Quote Originally Posted by HARVZ-6 View Post
    No, I fitted the exhaust myself not two monthe ago, standard system, at first I thought it was a defective system but as described to me the standard mufflers flow to the back then to two forward chambers then exit. The rear chamber had near burnt thru, totally burnt the alloy coating, the muffler man said for it to burn like that it would have to be red hot.
    The rear muffler had these spots on it too, altho not as bad as the middle muffler.
    rear muffler is also stock replacement. (origional supplier told me it was sports).
    I fitted this system myself so I know what it looked like.
    I had the middle muffler replaced with a proper sports one, but damb wish I had of got the right system in the first place.
    I sprayed some silver onto the new middle muffler and the rear one for the trip home on the express way but nothing burnt off for the 15min trip.
    VB SL/E
    Dec 2008
    Would a faulty o2 sensor run lean?
    I thought they were programed to run rich if they dropped out?
    VS Berlina 3.8
    Dec 2008
    Yes, a faulty O2 sensor would do that. It could be that because your O2 sensor is faulty, it is giving bad readings that say that it is running normaly. Again, any error codes?
    Dark Blue VS Stato
    Jun 2009
    G-Town Australia
    best option is check ya falt codes see if o2 comes up and replace
    VS Stato
    Soundstream Comp series throughout with 2, 12' subs, 1 4channel amp, 1 mono block, 2 6' splits in front and 6'9 in rear pushing out 148DB. also now running a 2.5 farad capacitor .. and D34 Yellow top
    1/4 mile : 593RT Running 15.9's with cat back Exhaust
    REGESTER HERE FOR FREE MONEY
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if the O2 starts to get bad it normally reads to low a voltage so the ecu richens things up to correct it.or they drop out all together.what sort of driving do you do lots of sustained high speed stuff.it could just of been bad muffler design
    VS exec
    Jun 2009
    bong from the gong
    unburnt fuel getting pushed out into the exhaust can cause this to happen
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Chances are it was a faulty muffler. Sometimes they stuff up in manufacturing and the muffler has too much restriction. Especially if the heat marks were where the baffles are. Some cheap systems aren't too good either and do that too.
    Visit my Facebook page
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    I would be using a heat gun and do some temp checks around the exhaust ports of your heads and compare with another non overheating commodore. If they are the same then its just a poorly manufactured exhaust system causing your worries.
    Reaper
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Just to understand it a bit better....the exhaust hasn't gotten hot since you changed the front muffler?
  16. #16
    VS l67 statesman
    Dec 2008
    As said before a restriction somewhere in the system,
    but You dont have any signs of a faulty valve in the motor by any chance ?
  17. #17
    VB SL/E
    Dec 2008
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Correct, but the o2 sensor is still showing code 13, sorry should have been more clearer when I said it was in fault.
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Changing the muffler points to that being the problem. A faulty O2 sensor won't cause what you were experiencing.
  1. [VIC] VN-VS 2.5 exhaust, & vt-vy twin 2.25->3" exhaust
    By jenkos_vl in forum Parts And Other Items For Sale
    Last Post: 24-07-2009, 11:56 AM
  2. Wanted VS V8 exhaust / HSV exhaust / Merge pipe
    By prettyboringbloke in forum Swap / Wanted to Buy / Trade
    Last Post: 21-02-2008, 03:06 PM
  3. List Of Exhaust Quotes no it's not another exhaust question:)
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-11-2006, 08:57 AM
  4. VT Exhaust (not jst another exhaust thread)
    By raZel in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-09-2006, 03:50 PM
