in the past week, my car has been a bit rough on idle and occasionally on start up, it seems to be fine but every now and then it is a bit jerky on idle, feels a bit lumpy and a jerk on the car. have no idea what it could be?
Check codes, maybe o2 sensor
So if you get an oxygen sensor error every now and then, and you have a rough idle, would it be a good indication that the o2 sensor needs to be replaced?
Sorry to hijack your thread, mr OP :P
Check this out:
VS rough on start up, then fine
PSYKO PHEONIX has been working on this issue for a while now
cheers
I've made her a Hold-On Commodore
Foam Tuned 1995 VR Series II - 9psi Boost - Manual - FM Intercooler - 3" S/Steel Plumbing
Super6 Injectors - Ceramic Wrapped Genie Extractors - 2.5" HiFlow Cat - 2.5" HiFlow Catback Exhaust with a 4" Dump Resonator
must be coil pack fouled or injector leaking.. as i was checking my vr on gas analyze .. and found very very high CO and hydrocarbon... and run rich ad bit rough idling ... that what i saw it also its my think abt this cheers
