Results 1 to 3 of 3
Thread: wiring diagram for demister on vs 6
    VS executive
    Jun 2009
    Default wiring diagram for demister on vs 6
    ive had some heaterfan problems of late which i thought were related too the demister , now after replacing every fuse and relay i could find the fan works everytime apart from when the demister is pressed , i have no idea where too go next so i guess its time too check connections .... which ill need a wiring diagram for i guess.
    VS Commodore
    Jul 2009
    I have had exactly the same problem in my VS, however my heater goes on and off as well even though I've changed the thermal resistor. What did you do to fix your heater?
    VS executive
    Jun 2009
    changed out the cage looking thing inbetween the wiperblades under the plastic cover under the bonnet and replaced every relay or fuse i could find related to the fans or demister.
    still does it, just not as bad now.
  1. VT V6 Wiring Diagram
    By Snowy7 in forum Electrical Wiring / Questions
    Last Post: 06-03-2010, 10:01 PM
  2. VL Wiring Diagram
    By stockies in forum Electrical Wiring / Questions
    Last Post: 27-05-2008, 01:01 PM
  3. wiring diagram
    By rangaman in forum Electrical Wiring / Questions
    Last Post: 30-04-2008, 08:51 PM
  4. VT Wiring Diagram
    By wh33lz2006 in forum Electrical Wiring / Questions
    Last Post: 19-08-2006, 02:23 PM
  5. need wiring diagram for:
    By Troy711 in forum Car Audio
    Last Post: 01-05-2005, 11:20 AM
