Results 1 to 4 of 4
Thread: Noob Question
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Default Noob Question
    This is probably a stupid question but I need to ask, What the hell is that metal tube, probably about 2cm diameter that runs just up and to the left of where the clutch would be on a manual up to the vent and heating controls? It always gets red hot and heats up the centre plastic guard.
    Is it some sort of heating tube from the engine bay to blow hot air. Should it be getting too hot to touch? (like, it will almost take the fingerprints off your finger if you touch it) or is this a sign of some sort of problem? Its bloody hot regardless of what temp the vents are on, or if they're even on at all.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It's the heater pipes, hot water from the engine flows through them to the heater core. It supplies the heat for your heater.
    MY RIDE
    Vee-ard's Avatar
    Jun 2009
    Bayswater, WA.
    Thought so, but it gets waaaaay too hot
    *edit* probably related to me needing to change my thermostat....
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    probably related to leaking heater tap aswell....like mine.
    Reaper
  1. Noob question
    By DrJeckyl in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-04-2009, 03:17 PM
  2. Total Noob question
    By younglion in forum Car Audio
    Last Post: 10-03-2009, 01:24 PM
  3. Quick noob question: oil cap.
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-08-2007, 09:44 AM
  4. noob question
    By nathans1987 in forum Car Audio
    Last Post: 18-07-2005, 05:31 PM
Tags for this Thread
