Results 1 to 8 of 8
Thread: Serpentine belt noise
    VS commadore V6
    Mar 2007
    Default Serpentine belt noise
    Hi all, a few weeks ago I had a very sweaky serpentine belt which I have replaced and also put 2 new idley pulleys on as the bearings were shot in them, that got rid of the sweaky belt problem but I have noticed when I first start the car, I get like what sounds like a light rattling metal sound thats only present for about 3 - 4 minutes upon startup, once the motor is warmed up it runs fine, no noise at all.
    I have checked all pulleys they sound fine and all nuts are tight, took off the belt a couple of times and refitted it, thought I may had installed it right but it looks fine.
    I thought maybe the tensioner pulley but that is hard to move, but does sweak when pulling it down to fit the belt.
    I took off the belt and started it up for a minute, no noise at all, any ideas guys,
    thanks
    Rony
    POVRTY's Avatar
    POVRTY is offline building 5L VB TH 400
    VE SSV 6SPD WGN
    Dec 2005
    taree nsw
    SV62NV's Avatar
    SV62NV is offline Scuba Steve
    MY09 VE SV6
    Mar 2009
    Kurunjang
    i also started hearing that type of sound in my car when i first started it and did some searching...
    the problem was i had less than a litre of oil in my engine
    note to self: change oil every 10000km not every 20000km lol
    but it could be a different situation with you as you mentioned it could be belt tensioner
    VS l67 statesman
    Dec 2008
    I have a similar rattle are start up but its the cat ,Have you tried starting the car with the belt off so you know for sure its one of the bolt on acessaries and not something else?
    VS exec
    Jun 2009
    bong from the gong
    Sounds like a bearing to me, i would spray some wd40 onto a pulley start the car and see if its there. Do one pulley at a time to try and work out what one it is, just remember you are treating the symptom not the problem
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    i have just spent the arvo changing my pulley's........turns out its the Altenator Bearings (they are a bit dry). i am about to pull them out and change them...or grease them up....but it sounds like the same thing...
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    maybe the pulleys have been on the self to long, or runners for the bearings has dirt or little dent in it, like when a cv joint is knocking
    Tit-Tit-Titian™
    VS commadore V6
    Mar 2007
    Thanks everyone for your replies, I have spun all the pulleys around including the alternator and they are all fine since replacing the 2 idley pulleys, took the belt off and started the car for a minute and no noise at all, so I am still swaying towards the tensioner pulley as it is the original one, since I have had the car since it was only 12 months old.
    The strange part is the tensioner pulley is hard to pull down when replacing the belt, it is not weak as you would expect, but does sweak when moving it down.
    thanks again guys.
  1. LS1 Chev Serpentine Belt
    By IanG in forum LSx Development and Modification
    Last Post: 08-06-2006, 05:51 PM
  2. v6 Serpentine Belt
    By bradson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-06-2006, 11:40 AM
  3. Driving without a serpentine belt
    By kojamoz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2006, 09:09 PM
  4. serpentine belt
    By drd180 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-03-2006, 12:20 PM
  5. Serpentine Belt Wear in VR
    By spill in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2005, 02:42 PM
