Results 1 to 11 of 11
Thread: Milky oil, compression test ok?
    97 VS
    Jun 2009
    Default Milky oil, compression test ok?
    So i definitely have water in my oil, a fair amount by the looks of it too. Did a compression test last night, and it was ok. I'm unsure of what to do next? I need the car back on the road by tuesday. any ideas would be good. thanks
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    97 VS
    Jun 2009
    that's what i was thinking, but was told if the inlet manifold gaskets were gone it would show up on a compression test? is this correct? One cylinder was a bit down compared to the rest, but was still in the normal range. This is driving me up the wall. I need my car back on the road ASAP. Thinking i might just bite the bullet and take it to a mechanic. I dont have time to waste with this guesswork
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Water in your oil and by the sounds of it a large amount normally means your Head Gaskets are blown. Could be your inlet manifold gaskets but I'm leaning more towards Head Gaskets. Best bet with situations like these is to take it to a mechanic. Probably wouldn't advise to kick it over either, thats IF the head gaskets are gone.
    ScoHar's Avatar
    ScoHar is offline Jizz in my pants
    02 VX Equipe V6
    Apr 2006
    CHCH, NZ
    Have you changed the oil run it again and seen if it still has water in the oil? i would head more towards inlet manifold gaskets, but as said above it could be head gasket.
    Gas, Ass or Grass nobody rides for free
    Quote Originally Posted by vsv8berlinawag View Post
    You tell him (coz you are right)
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    inlet manifold will not show up on a compression check as its ontop of the heads.
    Reaper
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Are you sure it is coolant going into the oil? Is the oil on the dipstick milky or just under the oil filler cap? If it is just on the cap, it could be just condensation. Have the cooling system pressure tested.
    (Wow....5005 posts.....)
    Visit my Facebook page
    97 VS
    Jun 2009
    Yes, coolant is definently in the oil. dipstick is milky. My biggest problem is the car is in my garage at home. Don't want to drive it and risk any further damage. So getting it to a mechanic is quite difficult under the circumstances. Im thinking i might drain the oil and put fresh oil in and limp it the 20kms i have to my mechanic. was hoping to be able to fix it ourselves as funds are limited, but so is time. other car runs out of rego on tuesday and have a baby due to be born any day now...
    Quote Originally Posted by Not_An_Abba_Fan View Post
    FstStig's Avatar
    1993 VR Calais
    Sep 2008
    Oh Drag dude! What a time to have anything happen at once. Unfortunately for you it does sound like your head gaskets are gone if its under the oil cap and on the dipstick. Your best bet is a tow truck, unless you want to do your heads as well then your looking at even more money around $1000 or more.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I'm thinking intake manifold gasket, very common on the V6.
    VR Caprice
    Dec 2005
    Me, I am thinking Head Gasket but if you are going to do Head Gaskets you should do inlet gasket as well.
  1. vs commodore got milky oil
    By snowy213 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2009, 07:19 PM
  2. 10-1 compression test results?
    By calaiscruzer in forum V8 Development and Modification
    Last Post: 06-05-2009, 11:42 AM
  3. 5.0 Compression Test Results
    By Noy in forum V8 Development and Modification
    Last Post: 11-03-2009, 04:52 PM
  4. Please help Milky oil issue
    By V85000i in forum General
    Last Post: 14-12-2007, 05:54 PM
  5. Milky Oil
    By fjdave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-04-2007, 02:09 PM
