Results 1 to 18 of 18
Thread: auto shift kit...?help
    aussie_cruzin's Avatar
    aussie_cruzin is offline got boost
    T04 turbo r31 skyline
    Jan 2008
    Aussie
    Default auto shift kit...?help
    What would be a good cheap upgrade for my vr auto...shift kit 1,2,3 whats the difference...and prices if any1 knows for perth area..any help would be good cheers.
    Drop Clutch
    VS l67 statesman
    Dec 2008
    Jan 2008
    Aussie
    Quote Originally Posted by vsl67 View Post
    A corvette servo would be a good cheap addiction to the shift kit
    what does that do?and i dont have a shift kit i want one though..but i dont know prices and what the difference is between the different levels of shift kits..
    Drop Clutch
    VS exec
    Jun 2009
    bong from the gong
    In short they change how hard they shift and what revs/speed they change at Stage 3 is normally manualised in the fact you have to change it between the gears or it will not shift up or down
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    stage 2 will hold gear even at max revs. and combined with a Corvette servo gives hard and firm shifts.
    also apparently slow's clutch wear...
    Stage 3 Shift Kit is completly manualised auto. you HAVE TO shift it from 1-2-3-D and downshift to D-3-2-1. to stop....
    go with stage 2. buy a TRANSGO shift kit.... (try get it off ebay cause they are cheap as chips compared to some auto placces ebay want $219 and tranny mechanic will want 300 area)
    Feb 2009
    Quote Originally Posted by tt460 View Post
    JusT Beat me...haha damn you tt460!!!
    Jan 2008
    Aussie
    Quote Originally Posted by S2_VR_ View Post
    ohk thanks cheers for the info that helps
    also should my auto be running perfect before putting shift kit on?cos mine isnt perfect just wondering will it kill it or possible fix it???
    Drop Clutch
    Jan 2008
    Aussie
    And around how much would a mechanic charge to have the kit and corvette servo put in just a estimate so i have a idea..
    Drop Clutch
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    you should at least get a service and get it checked and any parts that are worn replaced also, that will ensure its going to perform at its best with the shift kit
    costs have been posted by members on here from $250-400 if you supply the kit and 500 for supply and install
    betts's Avatar
    betts is offline Double banger
    Built toyota surpa
    Nov 2005
    Just around the corner
    I have heard that if your auto isn't in good condition then a shift kit will just kill it quicker, and that they are only good in the long term on a box that is in decent condition. Can't say I'm 100% sure on that, maybe somebody else could clarify.
    Feb 2009
    yeah i was told that too, but you shuld be-able to tell if it's gonna last or not. wats the box like now?...noises, clunking??..not selecting gears?..
    VR V8 S pack Ute
    May 2005
    I installed a transgo shift kit, larget boost valve and a corvette servo into my reasonable condition 4l60e.
    The shift kit has just about finished it off. This is behind a 5 litre btw.
    Its been in since september last year, and I'm noticing it starting to flare between gears.
    It might be just the band is loose, but I'm sure this a direct result of the shiftkit.
    I'm not trying to put you off it, a love my shiftkit, its fantastic. But if your trans is already playing up, don't expect it to last too long.
    Cheers,
    -Tom
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    STAGE 1: Is better for towing and helps control torque I'm pretty sure
    STAGE 2: Racing style shift, much harder and firmer shift and holds it in gear at higher revs
    STAGE 3: Completely Manualises the auto, makes it like a clutchless manual in other words, it will only shift when you shift it on the control stick
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VS II exec.
    Oct 2008
    tarneit / torquay
    stage 3 is poo... unless you're like... i dunno.. haha.
    they fail
    stage 2 is good... like everyone said.
    stage 1 is pretty pointless...
    get your box serviced before you even think about getting a shift kit!
    im guessing perth prices are diff to melb prices..... but last year my ex paid 650 to get a stage 2 with corvette servos in his VS ute.
  15. #15
    VX BERLINA
    Mar 2010
    South aussie
    VS executive
    Jun 2009
    i went stage 1.5 ( described in the sticky at the top of this section ) without the corvette servo because the 4l60e doesnt like them and tends too die an early death or so i was told by every mechanic i rang.
    mine has 200,000 on the clock so i decided to play it safe.
  17. #17
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    lukesvxberlina; the corvette servo is the main part that engages 2nd from 1st. it has a larger surface area to push on therefore giving you a quicker shift. theres a heap of info on here, have a gander at the sticky or a quick search
    pillzor; installing a shiftkit with the servo can actually increase auto life. less time to change gear means less heat.
  18. #18
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the servo changes pretty hard just by itself saves the 2nd gear band burning up and holds the band tighter once in gear to stop the drum slipping inside it.with a decient shiftkit she will be solid thats for sure puts a lot of stress on things but the transgo shitkit can be tailored to suit your needs doesnt have to be chirping every gear if you dont want it too.the servo is also part of the 3rd gear circuit and helps the speed of the 3rd gear change
  1. Gear Shift On An Auto,
    By Terence in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2009, 05:30 AM
  2. shift kitted auto
    By vs-6 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2009, 11:05 PM
  3. Ls1 Auto Shift Kit
    By VU-S-LS1 in forum LSx Development and Modification
    Last Post: 12-01-2007, 12:03 AM
  4. shift kit for auto
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 05:40 PM
  5. Vs Auto Shift Kit
    By 64now95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2005, 07:30 PM
