Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Quest for good fuel economy. 5 litre auto
    Haydz's Avatar
    Haydz is online now 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Default Quest for good fuel economy. 5 litre auto
    Hey guys.
    since getting my exemption. i have realized its been using a fair bit more fuel than what other people have reported their cars of the same type use.
    so here is what i have done so far.
    1. Cleaned the Throttle body IAC etc
    2. Replaced the oxygen sensor
    3. Got 10mm leads
    4. New Spark Plugs
    Still yet to put the new plugs/leads in. and i have a bottle of Nulon injector Cleaner to go in.
    since replacing the oxygen sensor my fuel economy has gone from 20.5l/100km down to 18.4l/100km
    so im hoping the rest will fix it up to a more normal level.
    just wondering if there is anything else anyone can suggest to make it a bit better.
    the car is also going to get a wheel alignment. as it pulls to the left a bit.
    this is also for anyone who needs to cure there fuel economy problem.
    hsvpunk's Avatar
    hsvpunk is offline volunteer firefighter
    vy ss II M6
    Jan 2007
    Mornington, Vic
    WTF 20 per 100.
    Something is seriously wrong with your car dude. (hence thats why your here)
    I still cant belive 20 per 100,sorry 18.4 per 100.
    How do you drive, road wise highway, country?
    Im lucky to hit 14 per 100, and i do atleast 300-350kms a week. and thats highway, and stop start trips to amtes houses and shops.
    I cant say ive seen anyones that high.
    Maybe Mr Foam could share his thoughts, could be tune?
    dont worry, il start a ride thread soon.
    VP Executive R-spec
    Jan 2005
    The standard tune will do alot better than 18l/100. With a tune you can see a improvement of 1-2L/100 maybe 2L but 1.5 would be more typical I'd say. The whole Coolant sensor/ECU coolant circuit and thermostat areas are where you want to be looking for the problem and also the fuel pressure regulator. It _should_ use *just* under 10l/100 on a tune on the highway and maybe 11 without one, worst case. If it's 12 or 13 on the highway then it has issues that need some fixing, My VP goes about 650kms on a tank, mostly highway so it does still chew the juice considering the size of the tanks in these things but they are a bit thirsty engine after all
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    ok guys.
    well my driving is
    most of the time under a quarter throttle. maybe 25-50 kays of the 350 or so. under heavy acceleration.
    greeny. i spoke to wavez about getting a tune from you. probably be next pay day now. i splurged and bought new plugs and leads.
    Ok. anyone know how to test the coolant temp sensor? or just buy another one and hope that was the problem?
    not much highway in sydney.
    that was reset with a full tank of petrol.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Haydz just buy a new coolant temp sender unit, its not worth the effort to test them and its a fair chance it will be the problem. But thats bad fuel economy, im doing heaps better than that in my wagon which would be a similar weight. Do the plugs definatly, you will notice a nice little power increase if your old ones are worn and make sure they are gapped to specs too.
    If your running non stock wheels, do a check on your cluster to make sure the k's are clocking up close to what they should be. You got any of those 1 - 5km odometer check things on the freeways near you. If its out you can calibrate the dash to read right again pretty easy. It will help make sure you fuel readings are accurate.
    Reaper
    vs clubsport
    Mar 2009
    brisbane
    with alot of city driving (ie me going to work ) was pretty common for my clubby to be around 18l per 100 with full throttle being used like 3 times a week in traffic these things are terrible since putting the manual in i have been driving a bit harder and am now around 14.7 to the 100
    I have seen 20 - 100 km when i was sick one week and i was just driving in peek hour to and from home to pick my missus up
    My advise get a manual
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    this traffic was not peak hour. as indicated by my average speed. its a bit of both. traffic lights to 60-70 kay roads. with a bit of a blat in for good measure.
    im going to call peps now and get a price for a temperature sensor. and if its not to costly ill buy it if not it will have to wait till later
    Edit: 25 bucks from Peps auto spares
    VP Executive R-spec
    Jan 2005
    I see your speed average is 30 ks, my average speed is about 80 for lifetime of the car while I've had it, so that's a pretty big difference. Not sure how I would go putting around in heavy traffic like that, I don't think I'd have a car over about 1.8 litres if that's all I was doing
    vs wagon
    Jan 2009
    darwin
    put negative lead of multi meter on neg battery clamp pos in radiator water/coolant with engine running . a reading of no more than 500mv should be observed. any higher voltage and youhave electrolisis problems. flush cooling system replace with gm coolant and distilled water. you will be surprised at the difference it can make
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Convert to manual. Job done.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    VS Commodore Acclaim 1996
    Jun 2009
    Townsville, Queensland
    i dont have an 8 but, does it see, to be rivving higher than it should be?
    ever changed the dif?
    vs clubsport
    Mar 2009
    brisbane
    Quote Originally Posted by STEALTHY™ View Post
    2nd that 1 million times better to drive to
    Nanos's Avatar
    Nanos is offline Not a Mod
    VXII LS1 Berlina Wagon
    Aug 2007
    Frankston
    buy a ls1. lol
    currently my average speed is 47.2km's average fule is 12.7.
    i would be doing what everyone sugest's also i have noticed that no one has asked when you last changed your air cleaner or last time you cleaned it.
    STEALTHY™'s Avatar
    Jan 2005
    12.7 is good, under 10 is better
    I'll stick to my 5L thanks.....(and to think the 6 speed will be lower than that)
    cheers sexy
  15. #15
    '95 vr executive wagon
    May 2009
    Launnie
    try and replace your fuel filter,it can stuff your economy if its realy blocked
  16. #16
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    Hey guys. well some progress has been made.
    replaced the temp sensor. replaced the plugs and leads. and now gets 12 ish babying it. and 14ish normal driving. still on the quest to improve it a little. but now that its manageable im happy. and to the other posters.
    i cleaned the air filter just over a month ago. and fuel filter was replaced last week.
    and manual. i done that with my old car. if it werent my daily i probably would. but i just get sick of changing gears when you can be doing better things
    best time driving i ever had in a 3 seater auto ute
  17. #17
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    I average about 16.5L / 100kms city driving stop starting all the time. Pretty average, not bad, not fantastic. That's with a Foam tune, 3" cat back, HSV headers, the factory HSV CAI with an aftermarket flat panel.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
  18. #18
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    well after a few months. normal driving is now around 14 -15 with an average speed of 60ish. thats with a greenfoam tune and on 98 fuel.
    just wondering if there is anything else i could try to improve it a bit more? anythings worth a shot really.
    would the coil or dissy cap/rotor button cause excess fuel usage?
  19. #19
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Haydz quick question, did you replace the temp sensor itself or the temp sender unit? Im getting about 17L/100kms at the moment, and thats all highway driving. Its suddenly got shit after being about 15/100kms not too long ago, and nothing has changed with the driving style.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  20. #20
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Maybe high flow filter, CAI..
    Other than that no clue what else you can do...
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
  21. #21
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    hey man i replaced the temp sensor. the 2 wire one that goes to the ecu. it was about 40 bucks. at the same time i also replaced the thermostat. thinking it may be the wrong temp etc. but now that works perfect. sits at a quarter on the guage and goes up to half in traffic.
    also wombles i have a K&N Panel and a CAI also pacemaker extractors and a 2.5 inch cat back.
    i think i have an exhaust leak at anything above 3000rpm though. could this cause shit economy? depending on where its coming from?
  22. #22
    VS V8 Berlina Wagon
    Jul 2006
    i do drive the V8 from Sunshine (vic) to Albury every 2nd week and i get my fuel average down to 10/100, thats with a greenfoam tune, Pacemaker extractors, 2 1/2 cat back and standered 3.08 diff. Mate of mine who does the same trip only he dosent have a foamy tune but he has 2.93? diff and he gets 8.8L/100.
  23. Default
    Quote Originally Posted by Haydz View Post
    man, that's pretty good. i wouldn't expect to get too much better than that really. some cars are better than others after all. you would probably spend more money trying to save 1l/100 than it's really worth in petrol money
    Quote Originally Posted by zai View Post
    I am not sutpid
  24. #24
    VP Executive R-spec
    Jan 2005
    With my VP when the coolant temp circuit in the ecu broke my economy when to crap. That's the only time it's been bad. I mostly drive on the highway but I get just a little under 10l/100 on a straight run on the highway and with my normal 80% highway/town driving I get 12.3L/100, it can't do any better than that any everythings in good condtion etc.
    I don't run a tune with lean cruise on it. My friend has a VS stato, with the typical VR/S tune I do he makes 9.5l/100 on the highway (tested at the pump). Without the tune (which I lean out lean cruise a bit further and exented it's range) he makes about 10.5l/100 which we tested back to back on the same road. Droping 1 litre is about typical, but then again the base timing on other cars could be wrong or anything, there's alot of variables but It should allways improve a little bit with a tune.
    Anyway, on the highway depending on the car anywhere from 9.5 to 10.5 is normal with the VR and VS's. If you can't get it into the 10's then there must be something wrong with the car somewhere. Around the city averaging 60 km/h I would have thought 14 was pretty good for a 5 litre, that's a big heavy car with a big iron engine that takes a long lonnnng time to warm up after all.
    With the manuals you can drop a litre of two out of those figures
  25. #25
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    ill give it a test on pure freeway tonight and let you know how i go. im not really complaining about the amount of petrol it uses. but hey why not make the car the most economical it can be.
  1. Fuel economy, oxy censor questions, VS 5 litre
    By Cobez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-06-2009, 08:45 PM
  2. VN V6, good fuel economy?
    By Shifty1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2007, 04:35 PM
  3. FS; VIC mazda astina auto, great fuel economy
    By seabass in forum Vehicles For Sale
    Last Post: 01-10-2007, 08:44 PM
  4. Ridiculously Good Fuel Economy in VT SS LS1 (???)
    By holden#1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-04-2007, 07:52 AM
  5. Fuel Economy of Auto/Manual VZ
    By Utester in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-03-2005, 09:32 AM
