Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: holden vs eletronic speedo
    Holden VS Executive Sedan
    Apr 2009
    Blacktown
    Exclamation holden vs eletronic speedo
    my mate had a holden VS where he could changed the speed alert to a electronic speedo, and tried it on mine and doesnt work, anyone got any clues
    Tit-Tit-Titian™
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    hold all 3 down, then turn the car on......people say hold the 2 outside buttons...but on my VR i have to hold all 3 buttons down then start the car....
    SV62NV's Avatar
    SV62NV is offline Scuba Steve
    MY09 VE SV6
    Mar 2009
    Kurunjang
    Quote Originally Posted by S2_VR_ View Post
    beat me by about 5 seconds lol, yea as s2_vr said hold down the buttons and turn the car on, you will tell if it works
    if it doesnt work then your car probably cant do it, some cant do it
    VS exec
    Jun 2009
    bong from the gong
    The up and down buttons are meant to be temporary usage as it will revert back to the speed alert if you turn the car off.
    Pressing all 3 will keep it as a speed display untill you press all 3 buttons
    Apr 2009
    Blacktown
    Wat about a different computer, like a more advance one
    Tit-Tit-Titian™
    Apr 2009
    Blacktown
    like and advance mod chip or something, anyone got any clue
    Tit-Tit-Titian™
    VS SIII Ute 5.0L- Cammed, Stall, Headwork
    Nov 2008
    Sydenham, Melbourne
    with the berlina's and calias u have to hold down all 4 buttons i think. worked for me
    Apr 2009
    Blacktown
    mines only got three buttons, and we have tried all three down at once
    Tit-Tit-Titian™
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Apr 2009
    Blacktown
    GMHCalais is online now [TUKN20Z]
    VY SII 5.7 Calais, VS SS SII HSV Enhanced
    Jul 2009
    adelaide yo
    tried it today, worked a treat!
    anyone got any idea what the other sections were for if you pressed mode once again etc??!
    Slammed 5.7 VY calais II tuckin G8 20'z
    Apr 2009
    Blacktown
    Quote Originally Posted by GMHCalais View Post
    yeah thanks, but it still doesnt get me to the point of why mine isnt working, its frustrating me
    Tit-Tit-Titian™
    The1's Avatar
    The1 is online now A Memcal a Day Keeps..
    VS V6 Berlina Auto Series 1
    Jan 2005
    Toowoomba QLD
    VS Commodore Acclaim 1996
    Jun 2009
    Townsville, Queensland
    i tried mine, i have an acclaim with factory speed alert, i tried all 3 buttons and it did not work, i tried the outside arrows and it worked. try holding the buttons in until the motor is running? besides that i cant really help ya, sorry
  15. #15
    Apr 2009
    Blacktown
    Quote Originally Posted by KyleBrown92 View Post
    yeah i will, but its so stupid, like its so hard for just this little thing
    Tit-Tit-Titian™
  16. #16
    VY SS
    Jun 2006
    Albany
    from the off position push and hold all 3 buttons turn the key to ignition while still holding the buttons dont turn the key to start, keep holding the buttons until the number 100 shows up on the screen then let go of the buttons and then press the set button, then its done permanent until you disconnect the battery
  17. #17
    Feb 2009
    yeah as stated above.....if you hold just the arrows, i thinhk it's only temporary...i'll try the permanent way tomoz...
  18. #18
    Apr 2009
    Blacktown
    well i will try it tomorrow, but sure it wont do anything
    Tit-Tit-Titian™
  19. #19
    Aug 2008
    Alrighty well guys i just went out and fiddled around with my Speed Alert Thingy and i still have no clue what im doing but what does it mean when you press i think both arrows and turn the ignition on and the LED Light starts flashing? Is that normal and what does it mean because i have no clue?
    On a random note also when does the fuel light usually come on in a VR/VS as mine only comes on i believe when the tank gauge is flat on the bottom? Is that normal?
    Thanks
    Matt.
  20. #20
    VR II Executive Manual
    Apr 2009
    It flashes when it's in "speedo" mode. Really annoying, actually.
    EDIT: Oh, and my fuel alert (VR V6) goes with about 50km left in the tank.
  21. #21
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    The speed alert in my vs early series 2, you hold down the two outside buttons while the ignition is off, crank until the engine is running and release the buttons... the red led will be flashing, and you will have a digital readout of your speed. Mate of mine pulled his apart and bridged those two button contacts, and put a resistor in place of the LED... Permanent digital speedo!
    Holding down the set button while starting the car has different results. According to the VS II car manual... The speed alert has 4 preset speed settings. 110, 100, 80 and 60. If you press set and up at the same time, or set and down at the same time, it goes to the nearest preset in that direction. If you hold SET, start the car, and release set, You get the ability to change those presets. The number will be flashing. Change it to what you want, press set, repeat for each preset...
    Ah, the things you an learn from reading the instructions.
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
  22. #22
    Aug 2008
    I was just fiddling around with it again and i must of pressed something it didn't like and it beeped at me and the LED light became solid. It almost seems that i can get speedo temporarily but not permanent. Mind you im not actually driving it around yet so cant check for sure whats really happening.
  23. #23
    Apr 2009
    Blacktown
  24. #24
    E46 M3
    Jun 2009
    do you really need your little electronic speedo gadgets that badly?
  25. #25
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    Although temporary digital speedo readout works on all cars, permanent speedo will only work on some, not others... i cant get mine permanent
  1. Diff gears/speedo change, it can be done by Holden
    By Troy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2009, 07:48 PM
  2. Holden Commodore Speed Alert/speedo
    By MATT in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2009, 03:04 PM
  3. '99 Holden Commodore VS3 UTE - Speedo stops working!
    By pengoau in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2009, 01:09 PM
  4. Replies: 14
    Last Post: 13-07-2008, 04:10 PM
  5. Replies: 21
    Last Post: 11-07-2006, 08:13 PM
Tags for this Thread
