hi guy's previous owners or someone before them cut the wires right down low so i cant solder or earth them etc... will a TV repair joint Be0able to fix this ****-up...
cause Holden want's to STEAL $290 of my money for a new one....
IT looks like it can be opened, but i cant get it opened (cause i dont want to break it...) thanks guys. NOTE: there should be 3 wires coming from there..
i can get my hands on one if you want a new one posted over mate.they are cheap as chips from the wreckers
$25.00 from the wreckers almost anywhere.
and 3 Dangerous non ABS VN's
even for a T5 one?.... this is the one from my T5?...will it still be cheap, i went to my local wreckers and they said they didnt have any...delco...can u get them new?..or second hand?..
I'm pretty sure a VN/VP auto one is the same just different coloured wires. Can someone confirm this?
Also it's very common for the wires to snap off there.
yeah manual and vn-vp auto the same part the last one we bought was cheap as second hand just scope out a few wreckers
YAY!! so this is confirmed That i CAN use a VN Auto one?....I have a VN here that i can take it off!!....so yeah?...i can use the one from my VN?...
normally have plugs on the ends of the wires.will fit sweet as
well i dont know about direct plug in theres a possibuility that the plug may have changed between models but it will work
ahh k....so i'll have to heat the soldering iron up... thanks delco and wavez
ok, just went down there to get it...got under the car and started to unplug it....it did the same thing as this one, so i rang the wreckers, they have some there for $33,..so pissed off, $33 that ii shouldnt have to spend, but ohwell....thanks guys
why cant i use my Auto one?...........from my VR?
the vr has an electronic auto the vn isnt electronic
and your manual is also non electronic
Eureka styles!
the vr one doesnt actually make contact with the output shaft of the gearbox like vn-vp and manual senders and is only 2 wires.the vn ones actually connect physically via cogs
oh ok, i actually got it opened, wires cant be fixed.but i can get a VN one for like 25....thanks heaps guys
