Results 1 to 7 of 7
Thread: VR Gearbox Problems
    Jamesx341's Avatar
    Jamesx341 is offline xch4ser
    vn Calais
    Sep 2007
    Cranbourne
    Exclamation VR Gearbox Problems
    Hey guys,
    A mate of mine just purchased his first car a vr wagon. As i was driving it home for him coming into his street the gearbox starting to leak quite bad so i pulled up on his lawn and it sat there for about 5 mins. then wen we came back out to move it out the back yard it would not go into any gear at all... no clunks nothing
    I got under the car yesterday to take a look were the leak is coming from and it seems it is coming from a small hole in the bottom of the tranny. Not sure if this hole is meant to be there or not it looks to be man made but not sure.
    Anyone got any ideas on what is going on ? and can the gearbox still go into gear with no oil in it ?
    Thanks in advance James
    S2 VX V6 Berlina Wagon, 304 VL Berlina Wagon.
    Feb 2009
    Sydney, Little Bay..
    im pretty sure the gear box does not go into gear without oil.........
    and i wouldnt try it anyway.....
    where is the hole?...on the sump?...or...?......no oil is ment to come out of the box....at all....
    Jamesx341's Avatar
    vn Calais
    Sep 2007
    Cranbourne
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    if it's a fast leak i'd say it's a blown pump bush. apparently common on early 4L60E's, and being that it leaks into where the converter sits, it could come out anywhere in the bellhousing and you'll be looking in the wrong place
    my pump bush blew and within 30 seconds i'd lost enough trans fluid to inhibit movement. makes a lovely white cloud when it hits the exhaust too
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VR Sedan
    Jul 2009
    Question Blown pump bush
    Quote Originally Posted by TheForgotten View Post
    I can vouch for the lovely white cloud. Is the replacement of pump bush a job for a mechanic?
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    box has to be removed, might also check the torque convertor while your there, mine blew when the end of the torque convertor sheared off
    VR Sedan
    Jul 2009
    Quote Originally Posted by Zuicider View Post
    Thanks Zuicider, I suspected that might be the case.
  1. Gearbox Problems
    By ST.47.ES in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-09-2009, 05:48 PM
  2. t5 gearbox problems
    By blaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2009, 05:26 PM
  3. vp gearbox problems!! help please!
    By smooth92vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2008, 11:36 PM
  4. Gearbox Problems AGAIN!!
    Last Post: 03-05-2008, 07:44 AM
  5. Gearbox problems
    By hsvd_g in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2005, 03:17 PM
