Has anyone changed the lights behind the climate control unit on a '99 VS Statesman (ALWAYS HAD ONE BLOWN SINCE I GOT HER 4 YEARS AGO, THEN LAST MONTH THE OTHER ONE BLEW NOW I CAN'T SEE IT AT NIGHT TIME), my mate told me that it's not a globe and it's some sort of inbuilt led?
Just want to know before i pull it apart.
Thanks for any help.
There are two globes that sit at the top of the screen, but they are soldered onto the unit. They are each about a centimetere long and about 3mm thick. You won't really have to pull the unit apart to see them. You could probably find a similar globe and attatch that.
The ones in the keypad are screw in ones like in the dash.
Tube type for the top (can be replaced with LED's) be gentle with the LCD screen as they can develope bleeds very easy.
T5 neo wedge for the buttons.
and 3 Dangerous non ABS VN's
How does 1 pull out the unit?
I don`t want to break anything.
"Success is the ability to go from one failure to another with no loss of enthusiasm" Sir Winston Churchill.
My VS II Berlina Wagon
MY12 II SV6 Sportwagon
To good thanks for the help!!!!
http://forums.justcommodores.com.au/..._installed.jpg
Here is a pic of the LED's replacing the tube lights
Are they green or just clear?
I toyed with the idea of replacing them with led's and ended up going with normal bulbs, see:
Resistors and LED's - replacing incandecent bulbs
88GreenVN are they 12v led's?
Would you be able to fit a 3v 3mm or 5mm with a resistor in there you reckon?
Don't want to sound like a bit a of girlbut has anyone paid an auto elec or Holden to do it and what did they charge
I'm not to good with LED screens and soldering irons, i thought they would just be plug ins.
I have no idea to be honest - I just by in bulk from Ebay bloke (my brother said they would work as he is the electronic whiz for the family)
He did say that they have a risistor in them - tiny bugger too - and way too hard to solder together. So I just buy the completed T4 & T5 neo wedge units.
