hey everyone would wh statesman seats fit into a vs statesman
Yes but they are not a straight drop in.
Fronts are the same as fitting normal VT/VX seats in. The rear is a bit more difficult due to the adjustable rear headrests. Also the rear seat is a bit too small for the back and will leave a slight gap on each side.
to fix the small gap in the rear, you need the extension bit which comes from the wh to bolt to the side, and then it is a perfect fit.
