Results 1 to 4 of 4
Thread: VR help central locking problem!!!
    vr berlina v6
    Jun 2009
    in a house
    Default VR help central locking problem!!!
    hi, i have a problem with my central locking that ive never had before....the central locking is all willy nilly and sometimes it will lock only front doors, or none or work or do absolutely nothing..i checked the battery and some wiring which seems fine but its weird because it worked fine until today?? help!
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I know that when my drivers door is open the central locking and elec window don't work so i take a stab in the dark and guess maybe dodgy door looms or lock solenoids.
    wamboin23's Avatar
    wamboin23 is online now Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    seen this before, check if the power mirrors work when the central locking DOESN'T. they both earth off one wire through connecters.
    VB SL/E
    Dec 2008
    Sometimes the wire connector is at fault, coming loose sometimes, but the other day my back door stopped locking, I could still hear the motor trying to close the lock so I drowned the button slide with lube (not something really smelly like wd40 if you don't like that sort of thing) and just use a rag of something in one hand to protect the trim.
    I manually locked and unlocked it a few times while spraying and then used the remote and it come good.
  1. central locking problem
    By ktmarke in forum Electrical Wiring / Questions
    Last Post: 18-08-2009, 10:20 PM
  2. Central Locking problem
    By sdrambo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-03-2009, 02:48 PM
  3. (Another) VR Central Locking Problem
    By Riff88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2007, 12:51 AM
  4. Central locking problem
    By stmcomms in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-11-2006, 08:33 AM
