Hey guys, where is it located on the VS wagon and can someone show me a photo of it if possible. Thanks![]()
the bcm is located under the dash to the right of your steering wheel just put your head under there and you will see it
Icm and Bcm are 2 different things......
You are probably referring to the DFI module - it sits directly below the three ignition coils. I'm only guessing, but maybe DFI is the acronym for Direct Fire Ignition.
