Results 1 to 11 of 11
Thread: Mods needed for VS 5L to run low 13s
    vs 5.0 5spd
    Jun 2009
    Default Mods needed for VS 5L to run low 13s
    hi guys, At the moment i have a VS 5L 5spd with pacemaker tri Y extractors, 2.5" exhaust, LSD and a 3.7 diff centre. At the moment the best it runs is 14.4 at the drags. I want the car to run high 12s or low 13s but want the car to remain naturally aspirated. What mods would i need and what kind of money would i need to spend. I would like the car to also be reliable and be able to drive it on the weekends without a problem,a real emphasis on reliability. I live in Sydney/ North shore any help or businesses you can recommend would be great, thanks alot.
    VS exec
    Jun 2009
    bong from the gong
    put a ls1 on in it with a cam and edit, whilst not the cheapest it will be the easiest way of doing it.
    $2k should get you ls1 with box ecu and harness will be auto
    fitting cost no idea depends what you can do your self.
    $1500 should get you a edit and cam installed. With enough power to run a 12
    then its a matter of running a 12
    vs 5.0 5spd
    Jun 2009
    thanks for the help man, but really want to keep the original motor, car is really clean and trying to keep it as original as possible for future
    VP Executive R-spec
    Jan 2005
    Hi man I've run a 9.031 1/8th mile 660 foot, with a Auto VP with 3.45 gears stock stall and a 2.5 inch twin cat exhaust which would be a bit quicker than yours if you compare that to your half track time. And I'm also on a mission to run low 13's. High 12's really. Since that time I've got a twin system which gained me alot of power and currently over this winter putting a cam/manifold and ported head on it which should give me the time I'm after. I'm using a 212/222 cam, modified banana manifold with 10 inch runners and the heads will have about 80 thou taken off them (and ported). I'f you follow something like that you should get your time of low 13's considering my cars a bit lighter
    vs 5.0 5spd
    Jun 2009
    thanks for your help greenfoam how much would i expect to pay for this extra work keeping in mind i'm quite useless mechanically
    VP Executive R-spec
    Jan 2005
    Quote Originally Posted by painter View Post
    I'm doing mine myself, I have a budget of about $1300 to run a 12 but apart from the machine work on the head I have all the tools/welders etc to do it. It would be fairly costly to get someone else to do the work, you will need to buy a manifold and throttle body that's going to be the best part of 2 grand and maybe another 2 grand to get the heads machined and the cam put in
    vs 5.0 5spd
    Jun 2009
    mate happy to pay the money as long as the car is strong and not going to be a problem, i cant be bothered, so if anyone knows someone good on northern side of sydney that would be great help
    VE SS and VS Senator 215i
    Jun 2008
    Adel
    Quote Originally Posted by tt460 View Post
    This is a very expensive job man. people thinking they can do it cheap are kidding themselves!
    I think to run consistant low 13s, high 12s (depending how you drive it) you should just stroke it. That way your torque will go through the roof, and youll have a fresh engine. having said that, not to cheap. plus when you need your next power fix, you can start playing with bigger cams etc.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Depends what you wanna do, if your not worried with luxuires then just strip the car to a shell with enough bits just to keep it legal. Best way to fast cheap is to reduce your weight. Grab some alloy heads and a block too while your at it, fair bit of weight gone there in one hit.
    Reaper
    pedrotski's Avatar
    pedrotski is offline Big Stato!!
    95 & 96 VS 5L Statos
    Jan 2008
    Mandurah
    My vs statesman runs a 14.4 with an exhaust, cold air and a worked auto box.
    i think 4.11's, stripped car, slicks would be the best way to get into the 13's.
    Nitro is also an option.
    I only suggest these as your post seems to be more about times, If your looking for power, You cant go past a supercharger for price/performance.
    Oh and a rip shift
    vn ss
    Sep 2007
    central coast
    im not sure how far you can go with the stock manifold, but why not rebuild the 5L so its fresh with flat top pistons, shave a lil more off the heads and get a medium sized cam? that should give you the grunt and reliability, the cam choice is very important i cant really recommend one as i havent fiddled with 5l much, but im sure from reading greenfoams thread he definately knows what he is talking bout i'd be taking his advice where possible if it was me.
  1. vr ss mods
    By raulb4515 in forum V8 Development and Modification
    Last Post: 01-09-2008, 01:14 AM
  2. vxV6 mods,best mods to choose?help appreciated
    By benjamino in forum V6 Development And Modification
    Last Post: 11-06-2008, 09:51 AM
  3. what mods r for needed 4 supercharging
    By tntracing in forum V6 Development And Modification
    Last Post: 02-01-2008, 05:33 PM
  4. vr,vs body control module mods needed
    By stixx1 in forum Electrical Wiring / Questions
    Last Post: 05-02-2006, 09:25 PM
