Results 1 to 6 of 6
Thread: Vr brake fluid?
    VR Executive S 3.8
    Oct 2007
    Default Vr brake fluid?
    Can't find the brake fluid spec for my VR V6 in my manual. And can you recommend some brands? Cheers...
    Vy Sv8
    Jun 2009
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Valvoline performance Dot4 brake fluid. this fluid is blue so it is easy to see when you bleed it through.
    VrWagz1's Avatar
    Vr S2 exec 5.0 man Wagon
    May 2008
    wollongong
    Dot 3 or above is good, but dont mix them always bleed the new one through. I personally use castrol, but thats just whats available at my local store so i use it.
    Reaper
    VS exec
    Jun 2009
    bong from the gong
    Quote Originally Posted by VrWagz1 View Post
    Agree with bleeding it , given the age of the car complete new fluid is worth the cost.
    VZ AWD One Tonner
    Jul 2006
    All std Dot 4 fluid comes from the same factory in Europe, same factory that also makes some lines of Dulux paint. Only when you get into the racing brake fluids or synthetics are there different manufacturers involved.
    If it's just a street car, ANY Dot 4 fluid at $7 a bottle will do. If you're after a performance brake fluid then the stuff we use and reccomend is the TRW G600 Racing Brake fluid (and is still Dot 4 compatible) and $65 for a 1L bottle.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  1. Brake Fluid
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2009, 08:56 PM
  2. best brake fluid?
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-11-2008, 07:52 PM
  3. what brake fluid do i use?
    By ShIbBy_industries in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2008, 09:14 PM
  4. Brake Fluid... Which DOT?
    By VT Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-01-2007, 07:33 PM
  5. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
