Results 1 to 7 of 7
Thread: bloody lock
    VR Commodore
    Apr 2009
    Wollongong
    Default bloody lock
    Hey all i had to put a new door on my car and i have to change the lock
    but i cant manage to get the lock out, so could anyone please explain how to get it out
    cheers Digger747
    Vy Sv8
    Jun 2009
    Dont you take the interior cover off and just take out the whole handle???
    VR Commodore
    Apr 2009
    Wollongong
    Quote Originally Posted by vs-ute-119 View Post
    took everything off like the interior bit of the door and everything
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    The actual lock or the lock cylinder? Lock cylinder has a U-shaped clip on the back. The actual door lock requires disconnecting the rods and wiring, removing the 3 torx screws on the side of the door then maneuvering the lock/actuator assembly out from within the door. Might also need to remove the window channel if its the front door. Cant remember.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    vk executive
    Jun 2009
    all you have to do is remove the door trim then undo your outer door handle and the lock will come out with it then you undo the lock rod and circlip
    out pops your lock
    VR Commodore
    Apr 2009
    Wollongong
    ok cheers guys how do ya get the whole door handle i went down to the wrekers and had a go but couldnt seen to get it out
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Theres a long thin clip on the back of the handle. Slide it across with a screwdriver and the handle will basically collapse. Then you have to work the handle out by playing around with it a bit. Hardest part is putting it back together.
    My (ex)Ride
  1. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  2. bloody odd ! WTF ?
    By Trei in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2009, 06:34 PM
  3. Bloody car!!!
    By sydsider66 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-12-2008, 02:27 PM
  4. No chirp with remote lock.. what's dead lock?
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2008, 04:06 AM
  5. Bloody Car
    By greg644 in forum General
    Last Post: 28-04-2007, 04:09 PM
