Results 1 to 10 of 10
Thread: Idler pulley problem
    V-Josh-R.'s Avatar
    V-Josh-R. is offline NEED PACEMAKERS.
    94-VR Commodore Ute
    Jul 2008
    Default Idler pulley problem
    Hey all, (first post in a while )
    Well just recently i noticed a squeaking noise coming from the engine bay (who would have thought!!) ...i automatically assumed a slipping fanbelt however this isnt the case....i listened and tried to play it by ear but i couldnt place which pulley it was coming from...so using my special "Screwdriver Stethoscope" i listened closely to the auto tensioner pulley and it makes a really harsh grinding sound through the "stethoscope"...i just want to know if anyone else has had this problem and if i just have to replace the pulley/bearing or the whole unit? If so is it a hard job?
    Cheers fellas
    Holdens go fast...very fast.
    FORD:
    First
    On
    Rubbish
    Dump
    :P
    S> CLEAR REAR BRAKE/TAIL LIGHT UNITS ( Got both left and right, from a VR ute),GOOD CONDITION, $70PICK UP ONLY 2197 N.S.W. PM ME
    vs clubsport
    Mar 2009
    brisbane
    get a new pulley from repco there about $17 from memory very common takes about 15 min to change it
    cheers doug
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    V-Josh-R.'s Avatar
    94-VR Commodore Ute
    Jul 2008
    Ok ill definetly be doing that tomorrow.... Cheers clubby
    FORD:
    First
    On
    Rubbish
    Dump
    :P
    VS Berlina 3.8
    Dec 2008
    I'm fairly sure Repco have only started stocking metal ones. One cost me $45 (Holden were only a few dollars more). They will last much longer than the plastic ones.
    This is also a good time to change all three.
    vs clubsport
    Mar 2009
    brisbane
    yere i was talking about the metal one im probably a bit out of touch with retail prices tho sorry
    VS Ute & VZ SV6 Sedan
    Nov 2007
    lol . i just replaced all my idler bearings .
    that would be a 6203 bearing for the tensioner . got it from work dunno $ figure .
    and the retaining bolt has a left-handed thread .
    & as clubby sed , about 15 mins to do .
    greenacc's Avatar
    greenacc is online now Searching for the billion
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    the only problem with the metal ones is they don't have a lip on the outside .... so when your water pump seal goes and pisses coolant everywhere your belt can slip right off the pulley and you loose it. Luckily mine was found hanging on the sway bar, great save !!
    VS II exec.
    Oct 2008
    tarneit / torquay
    like everyone said...
    but just remember its backwards thread... i spent ages getting frustrated trying to get mine off just to realise its got "special" thread *rolls eyes*
    V-Josh-R.'s Avatar
    94-VR Commodore Ute
    Jul 2008
    Lol it was too easy..it literally took me 3 minutes to replace...
    FORD:
    First
    On
    Rubbish
    Dump
    :P
    98 VT Commodore
    Jul 2009
    Default Vt Commodore 1998 Series 1
    Hey guys,
    I have to replace one of the pulleys on my car and I guess that its the idler pulley i will check later on tonight to be sure....
  1. Pulley idler changes?
    By Aus78Formula in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 06:52 PM
  2. Idler pulley torque
    By tezza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-04-2008, 09:10 PM
  3. vt Idler Pulley
    By sheapard in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-10-2007, 06:07 PM
  4. idler pulley arm
    By daron in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 10:48 PM
  5. Idler Pulley
    By AirStrike in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2006, 09:29 PM
