Results 1 to 5 of 5
Thread: some 94 VR upgrade help
    Vt Clubsport
    May 2009
    Default some 94 VR upgrade help
    hey guys, firstly thanks for your time in reading this.
    i have a few problems and was wondering if anyone could help.
    1. i currently run my car on duel fuel, but whenever i switch to petrol, and put the foot down, at around 80 kmph the engine light (orange light) comes on, also noticing it doesnt feel like its performaing as well as it does on gas, which is strange. anny suggestions?
    2. i was wandering if anyone had some ideas to increase power of the car, some small cheap ideas, and some more expensive ideas, please keep in mind that i would like to keep it red 'p' legal.
    3. i currently have a v8 throttle kit on my v6 commodore, i was told to do this to increase power, but was later told that i would have to change "the neck" or something to make it work efficiently. can anyone clarify, if i should keep it on, and what i would need to do to make the v8 throttle efficient in my engine.
    once again i would like to thank you for your time in helping me, im sure you have better things to do, but i really do appreciate it. thanks guys.
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    V8 Throttle isnt really going to do much to increase power, as the V6 supplies pretty much enough air for the V6 engine, just make sure that you have a clean air filter (or you could get a more expensive performance filter from K&N, although some people will argue just how much better they are) and it should be fine.
    Best initial upgrades to do on a car are extractors and exhaust, maybe check spark plugs are clean and firing properly and maybe get some aftermarket ignition leads like top gun. maybe get onto yella terra and get some roller rockers with higher ratio's.
    I never use anything except premium fuel in my commy either.
    All upgrades you do to it though aren't going to double power outputs or anything like that, but when they add up will make quite a difference.
    If you're really serious, then go forced induction and super or turbo it. For low boost, stock internals are ok up to about 8 or 9 PSI, any higher and you need to start spending the big bucks to get things like custom forged pistons and the like.
    All of this stuff is pretty much useless though if you're bound by that stupid red P plate law. Move to WA, It doesnt exist. LOL.
    Matt02SS's Avatar
    Matt02SS is offline Donating Member
    VY SS + VY exec
    Jul 2009
    Port Pirie, SA
    MX83
    Jul 2008
    hills area, sydney
    JCCC NSW
    Quote Originally Posted by Troy711 View Post
    My mum dropped me off at work one day and she was doing 90 in a 60 zone. When I pointed this out to her she said 'shut up, if you don't like my driving you can get out and walk'.
    dan202's Avatar
    dan202 is offline ITZ A PIG
    I HOT VR
    Jul 2009
    lancefield
    Quote Originally Posted by Adriianz View Post
    hi mate your orange light could be oxygen sensor because of the water vapour from the gas and as far as mods gas can slow u down there maybe get our computer done with a better ignition curve gas likes to be more advanced
  1. VR to VS BCM Upgrade
    By Bilbs in forum Projects
    Last Post: 16-11-2010, 08:12 PM
  2. VT Cam upgrade
    By Kernal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2009, 12:13 AM
  3. First car, fix or upgrade?
    By manolis in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-06-2008, 03:57 PM
  4. cam upgrade
    By dmitch in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-10-2006, 12:35 PM
  5. want to upgrade
    By pommysvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-07-2005, 10:56 PM
