Results 1 to 9 of 9
Thread: Vs Cruise control not engaging..
    Vs Ute
    Jun 2009
    Default Vs Cruise control not engaging..
    hi guys having a few issues with my cruise control on my VS ,
    i can turn it on and off fine and the green light works, but it doesnt always engage when set is pressed. when it does work. the reset to re-engage it works, but the set button will just stop working when it wonts to and all i can do is reset/accelerate.
    ive checked fuses they apear fine and allsao had the stalk apart and it tested ok too, from other threads im thinkingh that maybe the set wire has a fault and hence only works when it wonts to, or the unit in the engine bay is faulty.
    any one had these issues before? any ideas
    thanks
    vs clubsport
    Mar 2009
    brisbane
    check to see if your crise switch on the brake pedal has not worked its way out a bit and is not disengauging properly all the time
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Quote Originally Posted by clubby_you View Post
    yep thats my guess too
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
    Vs Ute
    Jun 2009
    krzyvs's Avatar
    krzyvs is offline Stalker
    vs 2 spac/vp exec
    Aug 2007
    newcastle/sydney
    and if thats not the problem itll probably be you indicator stalk i recently bought one off ebay brand new aftermarket for $44 inc postage
    I don't fear the fall, I fear the sudden stop
    VS Statesman
    Jun 2009
    I just recently fixed mine. I found it to be a broken wire in the Indicator stalk. Nothing that a bit of solder and heatshrink cant fix. Works good as new and am loving the Cruise control. Haha
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Could be the brake light switch, or the failsafe switch located above the brake light switch heading towards the top of the brake pedal stalk. From memory both switches have a degree of adjustment in them, so it might be worth having a play with the switch and see how you go.
    Vs Ute
    Jun 2009
    i pulled out the top switch and shorted to simulate tyhe pbreak being on just inc
    ase it was making contact properly and it still didnt work.. im goin to recheck my stalk wires and see how i go..
    Vs Equipe
    Oct 2006
    i have a VS commodore equipe and i have cruise control all of a sudden my cruise control wasnt working it would turn on it just wouldnt work it turned out to be a faulty lead not sure if this will help you but it worked for me cheers mate and good luck with it
  1. Cooling fan not engaging
    By Wynnie88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2009, 11:07 PM
  2. Traction Control / Cruise control crapped out!!
    By DarkCrystal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2008, 06:37 PM
  3. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  4. VN Aircon Re-Engaging
    By Melfice01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-03-2006, 03:01 PM
  5. auto not engaging when cold
    By willi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2005, 05:57 PM
