Results 1 to 9 of 9
Thread: Vacuum hoses, one each side of manifold on a 304
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Default Vacuum hoses, one each side of manifold on a 304
    What vacuum hoses are they? One of mine has a split in it. They sit under the top engine covers along the fuel rail.
    Quote Originally Posted by wikky
    As already stated, mate you're an absolute gherkin strummer.
    VL 5L inj
    Sep 2007
    Woodburn, NSW
    the two that come to mind are from the map sensor and the fuel regulator, either way, it wont run rigth till you replace the hose.
    edit: unless you ae talking about the hoses about the diamater of your thumb that run along each fuel rail? thats the heater hoses. could be losing some coolant if its split.
    VR Caprice
    Dec 2005
    The 1 on the right hand side is a heater vacuum from the heater control. It's about 3mm round. It goes to a 1 way valve behind the motor near the coil.
    94 VR Statesman
    Aug 2006
    right on dude it controls the heater tap the one that runs through the middle is the vac hose for the MAP Sensor and the two on the back are for the brake booster and heater vents
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Wicked thanks guys. Spoke to my mechanic too, he said the same thing, but he said if i'm going to replace the heater tap hose, to replace the heater tap as well, because everytime he has done a hose on a customers car, the tap has basically fallen apart in his hands more or less.
    Wagon_Wheel's Avatar
    Wagon_Wheel is offline Drop A Patch....
    Aug 2005
    Mt Martha, Vic
    Meh, my old tap didnt brake, but i was replacing all my cooling system anyway so put a new one in along with new hoses etc.
    The old vac lines are terrible, ive replaced all of mine now, as soon as you touch them they just crumble they are so brittle
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Yeah this one is pretty haggard, mechanic is gonna do it for me on friday when he does a few other bits in prep for the dyno tune next week. May as well do the heater tap, they cost **** all anyway.
    VR Caprice
    Dec 2005
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Exactly. All hoses are being replaced friday, top and bottom radiator hoses and all the heater hoses as well as a new heater tap which i picked up today.
  1. Vacuum Hoses... Which Colour Goes Where?!
    By 1991_Vn2nV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2007, 02:37 AM
  2. Vacuum hoses for VS Commodore
    By noizwerx in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-10-2006, 10:23 PM
  3. Vacuum hoses on Varijet + 202 Blue Motor, VH Commodore
    By Dr_Mutley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-06-2006, 02:00 PM
  4. vacuum rubber hoses for heat control
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-05-2006, 11:03 AM
  5. Vacuum Hoses
    By Hoffy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-04-2004, 09:45 AM
